Painting Exterior Cinder Block Wall - Painting - DIY Chatroom Home Improvement Forum
Old 08-11-2011, 07:21 PM   #1
painting exterior cinder block wall
A deck is over our flat roofed two car garage. It waspoorly designed. water collects under decking and has caused some of cinder block walls to erode. But they are gray and brown to match other trim.on the house. There is no drainage issues at the bottom of the wall. One suggestion is to dig a tench at the bottom of tje wall. I think it makes an ready patch and paint job more complicated. Cant afford to fix boards
Ideas?
raised ranch is offline   Reply With Quote
Old 08-11-2011, 07:31 PM   #2
Tileguy
Bud Cline's Avatar
Rewards Points: 558
So..........There's a question in there somewhere?
XXX
Old 08-11-2011, 08:13 PM   #3
You are so right that the question disappeared. This is what happens when I use the droid to write stuff. Get so focused on trying to see what I'm writing, I forget what it was about!
Do we need to dig a trench at the bottom of the wall? Again, there is no drainage issue. The water does not collect at the bottom of the wall. It does drip down the cinder blocks from where previous owners attempted to create a drainage system, but it's a slow drip.
What products do you recommend for patching and painting?
Cement Block Wall Footing 99altrade Building & Construction 41 08-10-2011 12:39 PM
Stucco transition from wire & paper to block wall jmk909er Building & Construction 0 07-17-2011 09:39 PM
Fire blocking a wood stud wall built against cinder block. BasementVirgin Building & Construction 1 10-05-2009 11:02 PM
$4 per block for retaining wall? tmpyankee Landscaping & Lawn Care 7 09-10-2008 11:22 AM
Cracks In Block Wall Foundation vf100 Building & Construction 7 08-20-2008 09:48 PM
