Painting Exterior Bricks - Painting - DIY Chatroom Home Improvement Forum
Old 07-18-2007, 10:08 PM   #1
Painting exterior bricks
I am looking for advise on what type of paint to use on a brick entry way. It is three steps that lead to the entrance door. The house has cream siding, and the red bricks is throwing everything off. All suggestions welcomed, and Thanks to all.
helpless handyman is offline   Reply With Quote
Old 07-18-2007, 10:20 PM   #2
Rewards Points: 1,222
Paint the siding.
Tscarborough is offline   Reply With Quote
Old 07-18-2007, 10:34 PM   #3
Ha Ha, the siding was just installed.
Old 07-18-2007, 11:59 PM   #4
Paint/Faux Artisan
Da Vinci's Avatar
Use a good quality porch and deck enamel (acrylic not oil). If red is throwing it off, go with a dark gray or brown- that will tie it all together for you.
Bay Area Painting Contractor
Da Vinci is offline   Reply With Quote
Old 07-19-2007, 09:00 PM   #5
Thanks Da Vinci, you stated to use a dark grey or brown. I was thinking since the siding is like a beige color, I should go with something similar but a dark tone. What you think? Thanks
Old 07-19-2007, 09:47 PM   #6
Paint/Faux Artisan
Da Vinci's Avatar
You could paint it a darker shade of creme, but don't go too light- it gets dirty too fast and doesn't look right on a porch. The darker colors look more natural and give it a foundation...
Bay Area Painter
Old 07-19-2007, 10:13 PM   #7
Da Vinci, here's a photo, you can see the brick steps on your left. The concrete under the siding has been covered with white stucco. To me thoses red old bricks look ugly..There is no porch here. What do you think? Thanks
Old 07-19-2007, 10:36 PM   #8
Paint/Faux Artisan
Da Vinci's Avatar
This is a different situation- I misunderstood. In this case I would paint them either the same color as the siding or a shade or two darker. Either will look fine. If you are not walking on them, I'd recommend priming with BM acrylic masonry primer and topcoat with same paint as house. Painting same color will make house look larger. If you use a second color, don't go too dark- just a shade or two.
Good Luck,
Old 07-19-2007, 10:40 PM   #9
Thanks Da Vinci, I know you were imaging one of thoses manchines you've painted, lol. I will definately prime, and go with at least 2 shades darker. Don't want to go too light, it will get dirty fast.
painting my floor Eli Flooring 3 03-20-2011 05:11 PM
Garage drywall painting haylo75 Painting 18 11-12-2007 09:13 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 03:33 PM
Painting over wallpaper RussellF Painting 8 11-01-2006 02:42 PM
Hairline Cracks after painting parasailing Painting 8 07-24-2006 12:47 AM
