Painting End Table - Painting - DIY Chatroom Home Improvement Forum
Old 09-23-2010, 03:03 PM   #1
retired guy
igneous's Avatar
Rewards Points: 137
painting end table
I have a wood end table that has been marred and scratched over the years and not worth refinishing. I plan to paint it a matte/satin black. I don't know the species of wood. Any suggestions on primer (oil or waterborne)? I will either spray or brush with SW. Should I consider using flotrol? Thanks. Igneous
igneous is offline   Reply With Quote
Old 09-23-2010, 05:27 PM   #2
End Table
You can't go wrong with oil... some water based primers could work but you should do an adhesion test 1st. Zinsser oil cover stain or BIN Shellac primer, either of those will work for sure.
Flotrol will slow down the drying of paint allowing it to level out and look more like a sprayed finish. If you have a sprayer and the knowledge then spray it, unless you like the look of a hand painted piece.
Good luck
www.PearlPainters.com
Pearl Painters in Portland Oregon
quote=igneous;506161]I have a wood end table that has been marred and scratched over the years and not worth refinishing. I plan to paint it a matte/satin black. I don't know the species of wood. Any suggestions on primer (oil or waterborne)? I will either spray or brush with SW. Should I consider using flotrol? Thanks. Igneous[/quote]
Pearl Painters is offline   Reply With Quote
Old 09-25-2010, 04:38 PM   #3
retired guy
igneous's Avatar
Rewards Points: 137
Thanks for the speedy reply. I will look at Zinsser products and ask SW rep as well. The brush lines won't be a problem. It is kind of nice if they're not too obvious.
Painting a Banquet Table (Melamine Surface) jessi1 Painting 4 10-14-2011 02:57 PM
Tressle table - how to build? Knucklez Carpentry 1 10-24-2009 03:18 PM
Painting a new table white... Brandon19 Painting 6 09-01-2009 08:52 AM
Painting Outdoor Wood Table bwilliams320 Painting 2 08-28-2009 08:43 PM
Question about table saws,... tribaloverkill Tools 28 04-13-2007 08:47 AM
