Painting Electrical Pvc - Painting - DIY Chatroom Home Improvement Forum
Old 10-30-2010, 02:20 PM   #1
Rewards Points: 1,216
Painting electrical pvc
installed some electrical PVC in the basement finished room I am trying to paint it the same color as the room sort of light tan... so far 3 coats and can still see the writing on the PVC. I am thinking I should have removed the writing somehow before starting.. please advise a Little late.
COLDIRON is offline   Reply With Quote
Old 10-30-2010, 02:56 PM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Give the pvc a suff sanding and wipe it down. We have painted pvc interior and exterior numorous times using two coats of a quality acrylic latex paint. Usually two coats of a quality paint will cover. What kind of paint are you using?
housepaintingny is offline   Reply With Quote
Old 10-30-2010, 04:02 PM   #3
Regular latex wall paint Behr.
Old 10-30-2010, 05:34 PM   #4
Rewards Points: 526
That could be your problem right there. I recently painted my exterior pvc service conduit. I started with a thorough sanding, then went with Rustoleum plastic primer in the spray can, let it set up for week, then hit it with two coats of S/W finish paint. It turned of very well - feels like a factory finish.
Windows is offline   Reply With Quote
Old 10-30-2010, 07:10 PM   #5
Rewards Points: 616
I would say the Behr paint is the problem. I've painted lots of ovc always using Sherwin Williams products and two coats always covered it well
Old 10-31-2010, 11:05 AM   #6
Matthewt1970's Avatar
Rewards Points: 1,098
Well there's your problem.
Electrical Questions from a Foreigner mark_anderson_u Electrical 4 09-10-2010 06:46 AM
Changing from Electrical Cook Top to Electrical Range EkS Electrical 24 06-22-2010 10:43 AM
How to install new electrical box without attic access gilmores33 Electrical 10 02-14-2010 07:46 PM
Slight electrical current in bathroom faucet water + other unusual electrical events story Electrical 9 09-16-2009 10:28 PM
Electrical box replace,addiitions, city permits and looking for an electrician ramchy Electrical 3 08-02-2009 11:12 AM
