Painting A Dryer Vent Duct? - Painting - DIY Chatroom Home Improvement Forum
Old 02-26-2010, 10:24 PM   #1
Painting a Dryer Vent Duct?
Is it ok to paint a dryer vent duct? I read somewhere that the heat would cause a toxic reaction with the paint. Is this true? If so, is there a way around the problem? Thanks!
--Chris
sillyboy22 is offline   Reply With Quote
Old 02-26-2010, 10:59 PM   #2
You would need high heat paint
Old 02-27-2010, 05:15 AM   #3
Too Short? Cut it Again!
If it is a pvc type vent duct the paint will never stick. A plastic primer may not take the heat.
Old 02-27-2010, 08:30 AM   #4
It's an aluminum duct. I've never heard of high heat paint, but I'll check it out. Thanks!
Old 02-27-2010, 08:49 AM   #5
I can't seem to find high heat paint in any color other than black. I was hoping to paint my duct white so it blends in with the wall. Any ideas? Thanks!
Old 02-27-2010, 10:08 AM   #6
You are probably just finding box store barbecue grill paint or something? Try an automotive store and see if they have a white engine paint in stock? High heat stuff also comes in white. You will only need a tiny spray can if they sell such things? May need primer too for raw metal.
http://www.duplicolor.com/products/engine.html
IMO, high heat paint may be a bit of overkill for your application. On the other hand, a can of engine enamel will not break the bank I guess. I have used the stuff a time or two for painting antique radiators where clients wanted a certain gloss look. They haven't died yet from having the stuff in their interiors as far as I know. The thin coat of whatever you put on your dryer vent and toxins, if any, released is not what is gonna get ya of all the things outgassing in your house! Of course things are all cumulative so I don't mean to sound casual about it.
Since high heat paints have ceramic in the resins I would make sure to have at least a dust mask on as they will go airborne when you spray!
And it doesn't really matter for this post, but could you click on your username and indicate at least your basic geographic location? It will help us all if you have posts that are location sensitive in the future.
Old 02-27-2010, 04:07 PM   #7
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Basically any quality 100% acrylic latex will work. You don't want to use oil, as oil can not withstand heat as much as latex, the oil over time will crack and become brittle, you can even use acrylic latex on interior radiators with no problems, I would use something like Sherwin Williams Superpaint, as it can be painted over aluminium.
housepaintingny is offline   Reply With Quote
Old 02-27-2010, 06:06 PM   #8
Great! Thanks so much!
--Chris
Old 02-28-2010, 12:03 PM   #9
Matthewt1970's Avatar
Rewards Points: 1,098
Tags
paint dryer vent duct
Cutting through sill for dryer vent mjkpainting Building & Construction 13 06-05-2012 05:14 PM
Mount dryer vent on ceder siding, how? ninghai Plumbing 3 12-30-2009 09:30 AM
Dryer Duct Run Ddeck HVAC 6 10-10-2009 05:52 PM
Help/moving dryer vent mjkpainting Plumbing 3 11-13-2008 08:44 AM
Dryer vent and AC compressor - min. distance? RDS HVAC 5 05-04-2008 06:50 AM
