Painting A Dry Basement - Painting - DIY Chatroom Home Improvement Forum
Old 07-13-2013, 11:47 AM   #1
Painting a dry basement
Hi,
I've searched these forums for an answer to this probably obvious question, but I have found only posts about serious basement problems. I have a 60-year-old house with a basement that is very dry. The cinder block was painted several times over the years. The current paint is a somewhat dark green, which my wife would like to paint over with a lighter color. What is the best kind of paint? Interior latex? Exterior? I don't need DryLok or anything like that since I don't have a problem with water--I have a very well-maintained exterior drainage system. A previous owner may have applied something like it some years ago, for all I know, but in ten years I've NEVER had a problem with mold, mildew, water damage, flaking paint, etc. So can I just use Kilz primer and an interior latex?
Thanks!
rob365 is offline   Reply With Quote
Old 07-13-2013, 12:33 PM   #2
Jmayspaint's Avatar
Rewards Points: 534
Yes, kilz and paint would work fine.
If the existing paint is latex in good condition,you really wouldn't have to prime at all, just clean it and do a couple coats of paint.
Jmayspaint is offline   Reply With Quote
Old 07-13-2013, 12:56 PM   #3
Matthewt1970's Avatar
Rewards Points: 1,098
I agree, skip the primer.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 07-13-2013, 05:10 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 504
IF the original paint is latex
Tags
basement , cinder block , paint
Painting Basement Floor ckinser3boys Painting 5 02-08-2013 01:10 PM
Heat for a basement with Pellt Stove on Main Floor magnum44 HVAC 1 11-20-2011 08:55 AM
painting basement walls jdfields67 Painting 2 09-26-2011 03:43 AM
How to Prep. Basement Walls for Painting vcheez Building & Construction 37 08-12-2011 09:32 AM
Painting Basement Floor and Foundation Walls meth Painting 5 09-26-2008 07:54 AM
