Painting Dividing Lights - Painting - DIY Chatroom Home Improvement Forum
Old 12-03-2009, 08:51 PM   #1
I just added nine exterior windows that have those removable dividing lights on the interior. The dividing lights are pine and I put polyurethane on the side that faces the interior. I would like the side against the glass that faces the exterior to be white and have not had much luck painting them. I can't keep the paint on the flat face they are on. It runs around the edges and doesn;t coat well. Perhaps it doesn't want to stick to the polyurethane that ran down to the outside. I even tried a very thick exterior paint and got the same poor results. The previous owner did the same thing, painting the glass side and polyurethaning the side facing the room. She sprayed the white on. I am hesistant to try the same thing because she got alot of overspray. What is the best way to do this? Thanks
PerpetuallyRepairing is offline   Reply With Quote
Old 12-04-2009, 04:44 AM   #2
paper hanger and painter
chrisn's Avatar
Rewards Points: 122
Spraying is the only way, unless you get some frog tape and meticulously tape them all off, very tedious indeed, but it can be done.
Old 12-05-2009, 01:04 PM   #3
Would it make sense to use frog tape and spray?
Old 12-05-2009, 06:11 PM   #4
chrisn's Avatar
Rewards Points: 122
You really should not need to tape if you spray them properly
Finding underground electric wire for driveway lights. mitch21131 Electrical 25 09-24-2012 09:52 AM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
Painting or Replacing Canister Ceiling Lights justagirl Electrical 1 07-14-2008 04:38 AM
