Painting Dirty Walls - Painting - DIY Chatroom Home Improvement Forum
Old 04-11-2014, 03:30 PM   #1
Rewards Points: 83
Painting dirty walls
Before you paint a dirty wall I've read that you use a degreaser for better paint adhesion. Is it safe to use a degreaser on a bedroom wall with orange peel texture? Any recommendations on a product?
ttwin is offline   Reply With Quote
Old 04-11-2014, 04:25 PM   #2
Painting Contractor
Rewards Points: 79
If the paint on the walls has some sheen, you should be fine lightly scrubbing. If it is flat, you really will not be able to scrub very well. If it is an extremely dirty flat surface, you should prime with something like Bulls Eye 123.
VAProPainter is offline   Reply With Quote
Old 04-11-2014, 06:04 PM   #3
Rewards Points: 6,652
Wash them down with TSP. Then go over with Distilled water to completely remove any residue off of them.
Old 04-11-2014, 06:45 PM   #4
Rewards Points: 4,780
Personally I'd use TSP substitute nowadays.
jeffnc is offline   Reply With Quote
Old 04-11-2014, 07:24 PM   #5
Rewards Points: 83
Should I dilute the TSP?
Old 04-11-2014, 07:57 PM   #6
It should say on the side of the bottle. Just used the tsp liquid yesterday. My buddy mixed it up. Glug glug glug in a fiver the rest was hot water. No rinsing required.
Danahy is offline   Reply With Quote
Old 04-11-2014, 08:09 PM   #7
Rewards Points: 83
thanks
Old 04-11-2014, 08:24 PM   #8
Rewards Points: 5,974
Please post a pic of the brand TSP you used I don't think think I ever saw one that was no rinse. Usually if you want paint to stick you rinse, then you rinse again, then you rinse one more time.
Old 04-11-2014, 08:45 PM   #9
Those are the substitutes :-)
http://www.acehardware.com/product/i...ductId=1425219
Old 04-11-2014, 09:08 PM   #10
This stuff! Zoom in and bottom left part says no rinse... Available at SW
Photo of actual bottle.
Old 04-11-2014, 09:12 PM   #11
Poured half in 3/4 full hot water fivers twice.
Old 04-11-2014, 09:41 PM   #12
lol Yes, that is a TSP substitute, that's why it needs no rinsing. TSP stands for TriSodiumPhosphate. Note that the bottle says Phosphate free! Note that the product is "sp TSP pf", not "TSP". Maybe a little sneaky on the part of the manufacturer, but there you have it. The tech sheet for it states "This product is an excellent substitute to TSP".
The Following User Says Thank You to jeffnc For This Useful Post:
gregzoll (04-11-2014)
Old 04-11-2014, 10:10 PM   #13
It worked pretty quickly to remove 30 year old nicotine off some apartments walls I just did. I'd definitely use that stuff again. As far as a substitute... Honestly I saw the letters TSP and no rinsing. The rest of the words blurred out on my way to the counter.
Old 04-11-2014, 10:22 PM   #14
Rewards Points: 83
HAAH!!! Thanks guys this puts me on the right track.
Old 04-12-2014, 03:02 PM   #15
I thought it had to be a substitute.
painting a ceiling and partially down walls JeanneSprague Painting 5 11-01-2011 05:15 PM
Help painting RED walls WHITE, and Japanese style bedroom LynniieRockz Painting 11 10-16-2011 06:46 PM
Painting Calcoat Plaster Walls Rlearn Painting 0 03-14-2011 11:51 PM
Painting soot covered walls syogod Painting 11 12-22-2010 12:37 PM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
