Old 01-03-2010, 08:58 AM   #1
Painting a dining room table-Please help
I just purchased a large dining room table finished in a Shabby Chic finish and I just want to paint it a semi gloss or satin black. I am not concerned with wood grain showing, but want some paint that is durable and will last.
What is the best paint to use and/or most cost effective? How do I make it last?
mbreihan is offline   Reply With Quote
Old 01-03-2010, 09:39 AM   #2
WindowTreatment Installer
First you have to use a good primer so that the paint will adhere. If you paint directly onto the finish on the table your have problems. In this case because your looking for durable I would suggest using oil base products. Clean up will be messy and have stonger odor but will be much more durable and longer lasting then latex. For the primer either oil base kiltz or shellac base bin. For the paint I would suggest asking for a good quality oil base. Seme gloss finish will be harder then a satin finish.
bobtheblindguy is offline   Reply With Quote
Old 01-03-2010, 07:27 PM   #3
Take a look at Muralo Ultra Satin. It dries as hard as the old oil base paints.
slickracer is offline   Reply With Quote
Old 01-04-2010, 06:00 AM   #4
paper hanger and painter
chrisn's Avatar
I would use neither of these products, they are not needed. A QUALITY bonding primer such as Fresh Start will do what you need.Then any QUALITY 100% acrilic latex for the finish will do. An oil based finish would probably hold up longer as posted.
Old 01-05-2010, 08:25 AM   #5
sdsester's Avatar
Not sure I am convinced an oil based product would hold up any better on a kitchen table surface than a nice latex semi gloss with 100 percent acrylic. Do add Floetrol to the latex to get rid of your brush stroaks or roller cover patterns though. Do remember the paint will need to cure, especially latex, for 30 days before you set anything heavy on it. I would definitely degloss the current surface chemically or with good old fashioned fine grit sandpaper and use an alkyd primer. You could think about putting a watebased poly urethane over the top of a latex if you need the durability.
sdsester is offline   Reply With Quote
Tags
diining table, paint, refinishing
Insulating a cold/well room? Lynch Building & Construction 22 02-09-2013 08:51 AM
Help painting and decorating a kitchen/dining room melissaandkris Interior Decorating 6 06-19-2008 01:33 PM
"pass-through" from kitchen to dining room? scoobz Building & Construction 10 12-25-2007 09:05 AM
Hardwood flooring - 3 walls and a sunken living room basledder Flooring 1 12-09-2007 06:34 PM
Painting a two story room atn0930 Painting 16 07-08-2007 12:21 PM
