Painting A Difficult Wall. - Painting - DIY Chatroom Home Improvement Forum
Old 03-14-2008, 12:52 PM   #1
wfischer's Avatar
Painting a difficult wall.
A friend suggested to me that I could paint this room easily by using a 3/4" nap (or thicker) roller. Will that work, or am I going to be stuck painting with a brush?
wfischer is offline   Reply With Quote
Old 03-14-2008, 03:57 PM   #2
DepotDweller's Avatar
I'd think if you rolled, you won't be happy and will end up pulling out the brush......I'd brush it from the get go.......unless you can spray it. Hmmmm, maybe brush the crevaces then roll? eh, I'd just brush.
p.s. have the kid do it.
DepotDweller is offline   Reply With Quote
Old 03-14-2008, 04:18 PM   #3
wfischer's Avatar
LOL. Not my kid, and he's no help anyway. His mom helped with some of the work I did in the kitchen, but I'm planning on painting over Easter weekend and I'm guessing she probably has plans. Nope, I think I'll be doing this one on my own.
Part of the reason I don't want to brush is because I'm stuck with Behr paint, which isn't known for its superior leveling capabilities.
Old 03-14-2008, 05:06 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
Your going to need brushwork there anyway
I'm sure those slots will need it
But you'll need it around all that other stuff anyway
slickshift is offline   Reply With Quote
Old 03-15-2008, 01:36 AM   #5
wfischer's Avatar
Are you volunteering to help? =)
Old 03-15-2008, 04:42 AM   #6
3/4 inch nap roller and a 4 inch block brush.Roll out the large areas and back brush to flatten out fat lines,while cutting in all corners ect. Looks like a tight area,Almost like painting a bathroom........I am betting another sheen will be applied as well..........Good Luck
mark942 is offline   Reply With Quote
Old 03-15-2008, 07:44 AM   #7
<waving hand> I've never been to Alaska!
Old 03-15-2008, 08:14 AM   #8
Building and plumbing
USP45's Avatar
Rewards Points: 150
Have a paint ball fight!
serious, i would brush then roll
USP45 is offline   Reply With Quote
Old 03-15-2008, 08:25 AM   #9
DAMN, why didn't I think of that?
Old 03-15-2008, 11:36 AM   #10
wfischer's Avatar
Not only is it tight, it's an awkward area to paint because of the stairs. I"m going to have to use a roller-on-a-pole, or rig something up to stand on, probably both to get certain spots.
Here's a couple more photos for you.
Painting a difficult wall.-dscf6848.jpg   Painting a difficult wall.-dscf6814.jpg
Old 03-15-2008, 11:46 AM   #11
Jack of Some Trades
Wood Butcher's Avatar
you MIGHT be able to do this whole job with one of those real small diameter rollers, the ones that don't go on a cage, but rather just on bent piece of rod ( they usually have a blue handle ) Those "joints" look pretty wide, so you might be able to get one in there. Go to the roller isle in HD and you will see what I mean
You will still need a brush to cut in, but these small rollers will go a lot of places full size rollers won't (GREAT for behind toilets)
Wood Butcher is offline   Reply With Quote
Old 03-16-2008, 04:49 AM   #12
Had to laugh when I looked at the new pictures,narrow,tall,crevices,flat,entry to another room. I think I would just mask the whole thing off. Booth it if you will.Hook up a 2` extension pole with a 4-12 tip and spray it all out. I am thinking a guy could stand mid way on the stairs and pretty much get to all he needed to get to.Ever try to put foot extensions on a step ladder? http://www.kk.org/cooltools/archives/001268.php I did, just for stairs. I wouldn't want OSHA seeing them though.................
Old 03-16-2008, 07:28 AM   #13
paper hanger and painter
chrisn's Avatar
Rewards Points: 312
Run away! Fast!
Old 03-17-2008, 09:05 AM   #14
wfischer's Avatar
Yeah, well that's what you get for buying a 5 gallon bucket of paint without knowing it's not a good brand first.
Old 03-17-2008, 05:03 PM   #15
Paint Contractor
A 9 inch 3/4 roller, 4 inch brush and the little giant ladder will do the trick! Back brush what you roll. It looks harder than it probably is and the longer you look and contemplate the harder it gets. You will be surprised that its not so bad!
movado is offline   Reply With Quote
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 09:11 PM
Marrying a sloping stone wall to a cinder block wall. mrdol Landscaping & Lawn Care 1 11-09-2007 04:08 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
Wall Patching Shows Through After Painting wcw5961 Painting 5 11-16-2006 05:33 PM
Load Bearing Wall? Traybae Remodeling 3 11-05-2006 01:39 PM
