Painting DensShield Tile Backer Board - Painting - DIY Chatroom Home Improvement Forum
Old 05-13-2008, 04:35 AM   #1
Painting DensShield tile backer board
I am having a problem with paint not sticking.
I have a ceramic tiled tub surround with DensShield as the tile backer board. The backer board was extended beyond the area covered by tile abutting (perpendicular to) an aluminum window frame. This left an approx. 3" strip between the finished side of the exterior wall of the house and the start of the tile, which was painted. Within this strip the paint would “bubble” when the shower was used. Two days ago, I scraped off the old paint, coated a rusted screw head with Jasco Prep & Prime and filled a 3/16” deep by 1” diameter area around the screw head with Dap Presto Patch. Yesterday I sanded the Presto Patch and primed with Zinnser Bull’s Eye 1-2-3 primer. After about 6 hours, as I was applying all-purpose joint compound to a nearby (higher) area of wall, some splashed onto the primer coated area. As I cleaned up the splashed joint compound, the primer under the splash peeled right off. I am concerned that simply repainting will not be enough to avoid the same problem in the future.
Was this a matter of simply not letting the primer dry long enough or is there a sealer that I need to apply prior to the primer? (e.g. Can shellac be painted over?)
Here is what Georgia/Pacific (DensShield manufacturer) says about painting over the backer board:
Q:
Can I paint DensShield® tile backer outside the shower area in a typical residential bathroom wall installation?
A:
Yes, the steps to accomplish this are quite simple. First, finish the joints using fiberglass mesh tape and setting type joint compound. Next, skim the entire DensShield panel surface with setting compound. Once this material dries out, prime and paint, or prime and paper. The use of setting type joint compounds are preferred over ready mix joint compounds near moist areas.
I’d like to find an alternative (and just as good) way to solve this problem. Although I have not checked yet, I’m guessing that the minimal amount of setting type joint compound I can buy nearby will be much more than needed for this small area.
The total “problem” area is less than 1 SF.
Any information/suggestions/solution you can provide will be much appreciated
warriorfox is offline   Reply With Quote
Old 05-14-2008, 09:34 PM   #2
ok her you go
scrape off anything on the surface that will come off in one minute of work
sand it for 1 minute
wash up that can of 123 really nice and exchange it for a can of kilz
let the kilz or other oil primer dry the recommended 45 minutes (4 hours for regular oil primer, do not use the spray can version)
repair your spot with any patching compound, and let it dry very well (hours) kilz that spot again as a primer and you're ready for painting.
Why did it fail?
123 is the best primer- that is it is the best at failing at everything it proclaims to be. it does not absorb, it skins over and peels every chance it gets, it is terrible and the slowest drying latex product on the market. FYI you can get a very small container of sheetrock 20 or durabond for 5 dollars (in a box at home depot) or you could-if you are really frugal, grab a scrap piece of drywall from the depot (there is tons of it everywhere) and grind up the plaster inside until it is like sand, add a tiny bit of water until it is like toothpaste, apply it right away, and it will be dry in no time (especially with a hair dryer held 1 foot away)
have fun dude
Q:
A:
ting is offline   Reply With Quote
Old 05-15-2008, 05:08 PM   #3
Thank you Ting
Not sure what you meant by "Why did it fail?" -- the paint or the "hole" in the DensShield? The hole in the DensShield must have been my doing.
In any event, I'll do as you suggest. Thanks for your input.
Hardie backer board DXS General DIY Discussions 2 03-17-2009 06:40 PM
Preping green board for tile? stbo2000 Remodeling 9 02-06-2008 10:40 AM
Backer board vs. plywood for tile underlayment allpraisebob Flooring 4 01-07-2007 08:44 PM
tile backer board yudamann Flooring 1 06-29-2006 08:53 PM
