Painting Deck - Too Late For The Season In Chicago ? - Painting - DIY Chatroom Home Improvement Forum
Old 11-03-2013, 12:49 PM   #1
Painting Deck - too late for the season in Chicago ?
Hello,
I have two decks - first floor and second floor - pictures attached. Didn't get around to scraping and painting it. Last paint job done about 5 years back.
I am seeing the green stuff (moss or mold ?).
We have 50 high / 35 low - for the next one week - some days rain/drizzle.
I am thinking of cleaning moss/mold with bleach and pressure wash.
After cleaning, should I attempt to paint in this weather or
IS THERE AN OIL that I can apply on it to get me through the season and temporarily protect it ? Both decks are in the back and is not being used - so no worries about someone skidding.
I can also lay a sheet of plastic on it to protect it ?
JB
Painting Deck - too late for the season in Chicago ?-deck-bottom-2.jpg   Painting Deck - too late for the season in Chicago ?-deck-top-1.jpg   Painting Deck - too late for the season in Chicago ?-deck-bottom-1.jpg
johnbalc is offline   Reply With Quote
Old 11-03-2013, 01:40 PM   #2
Or Should I leave it as is (not clean the moss/mold) for the season and deal with it in spring/summer ?
Tks
JB
Old 11-03-2013, 01:48 PM   #3
Jmayspaint's Avatar
Rewards Points: 534
It's risky to do solid stain this late in the year in your type of climate. Some solid stains are rated for low temp application, but still with rain in the forecast and short days (less sun to dry the wood) you would be taking a chance.
If you wash it now you will need to wash again in the spring before coating.
Jmayspaint is offline   Reply With Quote
Old 11-03-2013, 02:10 PM   #4
Thanks Jmayspaint.
Anything I can do give little extra protection over the winter ?
Is leaving the moss/mold as is better for the winter ?
-JB
Old 11-03-2013, 02:11 PM   #5
Jmayspaint,
Plastic sheet or oil coat for winter ?
Old 11-03-2013, 02:13 PM   #6
Jmayspaint's Avatar
Rewards Points: 534
An oil sealer is going to complicate putting a solid stain on in the spring.
Old 11-03-2013, 02:56 PM   #7
Jmayspaint,
Does plastic sheets on top help or does it trap more moisture and make it worse ?
Old 11-03-2013, 02:59 PM   #8
Jmayspaint's Avatar
Rewards Points: 534
Originally Posted by johnbalc
Jmayspaint,
Yea, that's what I was wondering. I'm not sure that putting plastic down would be a good thing.
Old 11-03-2013, 04:13 PM   #9
Gymschu's Avatar
Rewards Points: 180
No need to apply anything for protection over the winter. There's enough mold/mildew on there to keep it somewhat protected from the elements.
JMays is right. You really don't have enough time to prep (looks like some sanding is needed), clean, let dry, and finish. Even if you got everything prepped and applied a finish, you would be leaving that fresh coating to battle a tough Chicago winter. Waiting til spring makes the most sense since you won't be using your deck over the winter anyway.
Old 11-03-2013, 07:38 PM   #10
In a little over my head
Rewards Points: 706
I would put down a protective layer of snow and wait until spring to paint.
ratherbefishing is offline   Reply With Quote
Old 11-04-2013, 07:18 PM   #11
Thank You - Gymschu and Jmayspaint!
Thank You ratherbefishing - I will order some snow for delivery by Thanksgiving -direct onto the deck ;-)
Old 11-05-2013, 02:08 PM   #12
Rewards Points: 394
50 degrees Fahrenheit is the MINIMUM surface temperature for these products.
Will22 is offline   Reply With Quote
Tags
deck painting
Painting or staining a deck slug Painting 1 07-27-2008 02:30 AM
painting a deck shimp Painting 2 04-20-2008 02:18 AM
Painting my deck Floorwizard Painting 8 09-25-2007 11:32 PM
deck painting jane Stewart Painting 6 07-04-2005 11:07 PM
