Painting deck rails
Ranger, I can absolutely relate to tennis elbow and shoulder issues, it's got me as well. I brush and roll through pain on a regular basis.
Finish always peels down to the layer where the reason for the failure occurs. In your case, it's the wood and the first coat. Once stripped, you need a new plan of action. You know what they say about insanity. I like housepaintingny's (hpny) plan. I don't like using power tools for the stripping if using a non-solid stain. You could easily end up with a real non-uniform looking finish, and it's a much harder path. When staining, the depth of the sanding cut needs to be uniform. I think HPNY's plan, maybe in conjunction with a power wash, would be the way to go. You need to start from scratch, and his plan would cover the possibilities your finish failed. After you strip and wash, allow three good days of drying or till moisture content is 15-18%. And, however you apply the stain, it's imperative to back brush for maximum penetration. HPNY hit the nail on the head with all his recs. Good Luck.
PS No college, student, university, junior high, post graduate, painters.
Reason: add ps
