Painting Deck Railing...which Big Box Store Paint? - Painting - Page 7 - DIY Chatroom Home Improvement Forum
Old 05-15-2013, 02:25 PM   #91
retfr8flyr's Avatar
Looking good!! What color is that, looks almost like a light gray?
retfr8flyr is offline   Reply With Quote
Old 05-15-2013, 02:33 PM   #92
Dork Fish's Avatar
Bright white I believe. Unfortunately, going back to get more. Already went through 5 gallons :s
Dork Fish is offline   Reply With Quote
Old 05-15-2013, 04:51 PM   #93
paper hanger and painter
chrisn's Avatar
Rewards Points: 498
You would have used maybe a gallon brushing it. So after you are done buying all this paint, how much have you saved? Just curious.
Old 05-15-2013, 05:44 PM   #94
Too Short? Cut it Again!
Thought I mentioned it but bright white, or white white, can be fairly unforgiving.
Railing looks nice though. I assume other than using more than expected---and we warned you about spraying---the Woodscapes itself is working out alright?
Old 05-15-2013, 06:02 PM   #95
Dork Fish's Avatar
Yes, I am very pleased so far with the woodscapes. It is going on very nicely. You know with the time we are saving with spraying, I don't mind paying the extra for paint.
3 1/2 (32oz) containers of wood filler later. It is looking good.
Question: we really like the way the unbrushed second coat looks on the area between the spindles. Is it okay not to brush that area?
Oh yeah: it was (extra white)
Old 05-15-2013, 06:15 PM   #96
You mean the clouds in one picture or the lawn or deck showing between them in the others?
I am not sure I understand what you are talking about but to get an even stain film distribution you should backroll or backbrush everything.
Old 05-15-2013, 06:29 PM   #97
Dork Fish's Avatar
LOL, this area...
You can see the brush strokes even on the second coat.
Old 05-15-2013, 06:34 PM   #98
Dork Fish's Avatar
Grrrr, we checked the forecast multiple times. No rain until Friday. This came out of nowhere...
Old 05-15-2013, 06:39 PM   #99
Dork Fish's Avatar
Ugh,
Old 05-15-2013, 06:45 PM   #100
Jmayspaint's Avatar
Rewards Points: 534
Sd is right about back brushing for uniformity. But, if you are getting a good first coat, and brushing full all the knot holes, rough spots,defects in the wood, with the first coat; then there is no real reason( in terms of coating integrity ) that you have to back brush the second Coat.
Back brushing is about getting a uniform coat. It's also important on wood because it helps work the material into the wood, and promote a good bond. First coat is a must, second coat not so much.
If you are happy with the way it looks on the second coat not brushing, it won't hurt it not to, as long as your getting an even coat with the sprayer.
I'm glad this is working out for you. Spraying is faster and (to me) a lot easier.
Jmayspaint is online now   Reply With Quote
Old 05-15-2013, 06:52 PM   #101
Dork Fish's Avatar
Sounds great!
Old 05-17-2013, 06:55 AM   #102
Dork Fish's Avatar
We are done! (with the railings) Woohoo.
I am going to sand the facia boards this weekend. I decided to stain them to match the decking. If I like it, then I will hold off on wrapping it with Trex.
Then we should be able to dig footings, get the poles set and lay the decking.
Then it is on to the next project...the pergola!
Thank you to everyone for all of your help!
The Following User Says Thank You to Dork Fish For This Useful Post:
Jmayspaint (05-17-2013)
Old 05-17-2013, 11:44 AM   #103
Hopefully this will cause your crazed neighbor to STHU! Looks great. I think the facia looks to be in great shape and solid staining it to match the new decking should look really nice.
Old 05-17-2013, 12:04 PM   #104
Dork Fish's Avatar
Yeah, right !?!? But....technically, it will still be three different colors. LOL
Thank you! I did buy some woodscapes and had it tinted to match the Trex for the decking. Hopefully, I can get to that this weekend.
Slowly, but surely!
Old 05-17-2013, 04:24 PM   #105
chrisn's Avatar
Rewards Points: 498
Wow, now that I can see the scope of this project, I can see why you wanted to spray it.
Flat over Semi-Gloss dankreboot Painting 21 02-24-2013 07:46 PM
Painting over gloss paint on a Ceiling BSR Painting 7 08-23-2012 09:45 AM
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 10:43 AM
Painting Detached Garage Exterior bsmith95610 Painting 3 02-15-2011 06:52 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 10:00 AM
