Painting Deck - Painting - DIY Chatroom Home Improvement Forum
Old 03-07-2012, 03:51 PM   #1
painting deck
We just bought a house and the deck needs painted because it has a weird green/blue color on the banisters, is there a paint that looks like wood that we can just paint over the top of that paint with?
PATTY TOUNT is offline   Reply With Quote
Old 03-07-2012, 04:23 PM   #2
Mr. Paint's Avatar
Patty, Paint does not look like wood; it looks like paint. If the surface is a sound, paintable one, you have an issue of color. Cabot 1800 Series is a solid-color "Stain" that may work well for you. It comes in a wide choice of colors.
Mr. Paint is offline   Reply With Quote
The Following User Says Thank You to Mr. Paint For This Useful Post:
user1007 (03-07-2012)
Old 03-07-2012, 07:16 PM   #3
Rewards Points: 150
You need to find out what type finish is on the deck. You may not be able to just paint over the existing coat. You may have to strip, neutralize, allow to dry and then stain the deck properly. Have an expert look at it before you proceed.
CaptRandy is offline   Reply With Quote
The Following 2 Users Say Thank You to CaptRandy For This Useful Post:
Gymschu (03-07-2012), user1007 (03-07-2012)
Old 03-07-2012, 10:47 PM   #4
Rewards Points: 626
Sounds like algae! light pressure washing with a bleach solution and then stain it.
Nailbags is offline   Reply With Quote
Old 03-07-2012, 10:55 PM   #5
Rewards Points: 13,712
See how confusing the replys are without a picture.
Gymschu (03-08-2012)
Old 03-08-2012, 06:33 AM   #6
Gymschu's Avatar
Rewards Points: 832
If it's paint on the deck, you have a major issue. Paint is the worst product for a deck. It is not recommended for horizontal surfaces. The paint will peel in no time. Capt Randy is right.......if it's paint, you're gonna have to strip it off & that is no DIY job. Once stripped off, you will have to sand the surface down and STAIN it with a semi-transparent stain.
Old 03-08-2012, 11:31 AM   #7
Matthewt1970's Avatar
Rewards Points: 1,098
Right, but he said banisters and I think he is refering to the railings/spindles which are typically ok to paint even though I would still stain them if they were bare wood.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
Ground level deck - screws or bolts? rsmith0399 Building & Construction 9 01-11-2012 12:53 PM
Painting deck rails Ranger1227 Painting 4 03-15-2011 09:06 AM
painting over new solid deck stain passthepoi Painting 17 05-18-2010 11:36 AM
Painting a deck MIKE77 Painting 1 05-16-2009 08:50 PM
Building a new deck....and creative uses of granite scrap in outdoor living space Rhizzlebop Building & Construction 9 05-15-2009 11:17 AM
