Painting Dark From Light, How Many Primer Coats? - Painting - DIY Chatroom Home Improvement Forum
Old 05-10-2009, 02:46 PM   #1
Wink
painting dark from light, how many primer coats?
My walls are currently llama white, and a pale yellow. I'm wanting to change the color drastically to a deep bright navy. I've already used one coat of primer (blue) and was wondering however if I should do a second as the white still shines through? Also wondering if using a second coat of primer might limit the amounts of coats that I may have to do to reach the desired color?
Thanks,
Miss Molly is offline   Reply With Quote
Old 05-10-2009, 04:15 PM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
If you are tinting your primer, then yes, a second coat will make your top coat cover better.
Old 05-11-2009, 05:45 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 228
In 30 + years in the business, one coat of primer and 2 finish coats have worked for me but if you want to do 4 coats, a second coat of primer will not hurt.
Old 05-19-2009, 05:13 PM   #4
just use another coat
think of it this way ...
if you don't need another coat, it will save you $10-$40 and a few hours.
if you do need another primer coat, it will be a nightmare.
either way, it is just easier to put down another coat and not worry about it, especially if you didn't get the best primer.
the pro painter guys use better paint and primer.
Christy-Spencer is offline   Reply With Quote
Old 05-20-2009, 05:29 AM   #5
chrisn's Avatar
Rewards Points: 228
Maybe that is it. In my experience, only 1 coat of primer is ever needed, as 2 finish coats are always applied.
Old 05-20-2009, 09:56 AM   #6
Rewards Points: 506
Blue pigment has pretty good hide, so you don't have to worry as much about coverage as you would with a deep green, or worse, deep red. But if you do want to use tinted primer, a grey tinted to be the same "brightness" as the final topcoat is better than color-tinted primer. (Black pigment has the best hide of all, so if you want to cover up the white, it does a much better job than color-tinted primer.)
SirWired
sirwired is offline   Reply With Quote
Old 05-20-2009, 11:04 AM   #7
Rewards Points: 346
More than one coat of primer - totally unnecessary. Using quality primer and paint - priceless.
RegeSullivan is offline   Reply With Quote
Dark over light...Do I need tinted primer? melissaandkris Painting 17 09-09-2011 11:43 AM
I Hate Ice Stubbie Off Topic 20 12-21-2008 12:41 PM
Painting Bare Steel- Sand First or Use Etch Primer? scott890 Painting 2 10-11-2007 05:32 PM
Is it normal for primer to show thru dark paint on first coat? Autumnknight Painting 5 10-02-2006 07:38 AM
