Painting Dark Green Wall.....primer? - Painting - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-06-2013, 12:20 PM   #16
Rewards Points: 4,796
Yeah that too. I don't usually clean rollers, so for the roller cover, disposable tray liner, brush cleaning, and opening/closing cans, it's about $4-5 and 10 minutes every time I switch paint.
jeffnc is offline   Reply With Quote
Old 10-06-2013, 05:37 PM   #17
Rewards Points: 6,034
OK I guess i'm wrong, it's better to 3 coat with $50 paint than to use a $19 tinted primer. And it's better to go back the 3rd day for the final coat, when I can prime and 1 coat in 1 day and final coat the next. And the $4 or $5 you must not use drops and your driving time for the extra day is not worth anything.
Guys I agree in most cases but for some colors I still prime.
Old 10-06-2013, 08:19 PM   #18
Rubbin walls since'79
Brushjockey's Avatar
3days. Lol. 2 coats aura as fast as I can put them up, done. Or even Regal. Or even Ultra Spec.
New tricks>old dogs.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 10-06-2013, 09:26 PM   #19
Matthewt1970's Avatar
Rewards Points: 1,098
You are talking maybe 1 in 20 times of covering dark colors that it would need a 3rd coat, if that. Even less chance if it's the $50 paint and you can easily do 3 coats in one day, not 2 or 3.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 10-07-2013, 02:52 AM   #20
First, the $4 or $5 is not my total cost, it's the difference in cost between cleaning rollers and pans, and not.
As to which is more expensive, it's not as simple as you wrote, so you'll have to think about it more. I'll give you a hint. If a room has 500 sf, then it cannot be coated with 1 gallon - it takes 2. However it does not take 4 gallons to do 2 coats - it only takes 3. It only takes 4 gallons to do 3 coats.
2 gallons of primer, and 3 gallons of finish can cost the same or more than 4 gallons of finish paint.
And you definitely don't need to be using $50 paint either. $19 primer and $32 paint - do the math on that one and you'll see what I mean.
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Painting pine - primer? marliz Painting 17 12-12-2010 07:37 PM
Painting Kitchen Cabinets, Back wall NewlywedKristin Interior Decorating 12 03-18-2010 10:23 AM
painting dark from light, how many primer coats? Miss Molly Painting 6 05-20-2009 10:04 AM
Is it normal for primer to show thru dark paint on first coat? Autumnknight Painting 5 10-02-2006 06:38 AM
