Painting Dark Green Wall.....primer? - Painting - DIY Chatroom Home Improvement Forum
Old 10-04-2013, 06:43 PM   #1
Rewards Points: 1,050
painting dark green wall.....primer?
Hello
We bought a house where the previous owner painted the dining room in a dark green color......hurghhh!!!
I will repaint it with something clearer.
Do I need to prime the wall to better cover the darker color?
Or will I be good with 2 layers of paint?
If a primer or under layer is requested, what should I use?
french_guy is offline   Reply With Quote
Old 10-04-2013, 06:52 PM   #2
Rewards Points: 5,988
If it is like a hunter or forrest green you will need to prime since you are going much lighter a gray or gray tinted primer will probably work best. And no paint with primer won't work.
Let it begin.
Old 10-04-2013, 06:57 PM   #3
DIY staff
Rewards Points: 7,174
I agree with tool seeker---a primer will help you cover the deep color---I'd likely use a white primer---
A very high quality paint might cover just fine with out the primer---Your call---
Old 10-04-2013, 07:01 PM   #4
Is the primer the base they use to create the color you want by just adding a tint?
Old 10-04-2013, 07:02 PM   #5
Rubbin walls since'79
Brushjockey's Avatar
What? Primers don't cover well- they do other things- go straight to paint- faster, better. Particularly if you are using a quality paint
No need for primer.
Expect 2 coats of paint, not one coat of primer THEN 2 coats of paint..
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Jmayspaint (10-04-2013)
Old 10-04-2013, 10:31 PM   #6
Matthewt1970's Avatar
Rewards Points: 1,098
No need for primer.
This.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 10-05-2013, 03:33 AM   #7
Rewards Points: 4,796
You are painting with something "clearer"? I don't know what that means.
There is such a thing as a color primer, but it would be a shade of gray specified by the manufacturer to go under a particular finish color. Other than that, a good quality finish paint hides that last paint better than any regular primer. Primers just aren't formulated to solve that problem.
jeffnc is offline   Reply With Quote
Old 10-05-2013, 07:43 AM   #8
I assumed clearer meant lighter and we know what happens when we assume.And I agree a quality paint hides better than primer[I]in most cases.[I]But in going from real dark to real light (or clearer?) I like to use a coat of tinted or gray primer to sutler down the dark color.
I painted a bright yellow room once with a light blue and the whole room had a green cast to it even after 2 coats.
Old 10-05-2013, 08:41 AM   #9
I just painted my entry way that was burgundy red. I put 2 coats of paint on and it covered very well and looks so much better. It is now a blue-gray color!
Msniki is offline   Reply With Quote
Old 10-05-2013, 08:52 AM   #10
I have painted over some extremely dark colors and it is rare that a 3rd coat is ever needed. Even in those cases it is a lot easier to do 3 coats of paint rather than a coat of primer and 2 coats of paint. If you must put on a coat of primer and 2 coats of paint every time you have a drastic color change rather than take the risk of the still easier but rare requirement of 3 coats, be my guest.
The Following User Says Thank You to Matthewt1970 For This Useful Post:
Gymschu (10-05-2013)
Old 10-05-2013, 07:02 PM   #11
I'll do it every time I like the idea of insurance rather than a gamble.
Old 10-05-2013, 10:01 PM   #12
lol. What is the gamble? that it took 2 coats or 3?
Old 10-06-2013, 10:40 AM   #13
I guess the only thing you are insuring is that it will take 3 coats (1 primer and 2 paint)
Gymschu (10-06-2013)
Old 10-06-2013, 11:33 AM   #14
The only "gamble" when it comes to color is whether to color prime with the appropriate shade of gray. If you skip that step, you can't make it up later. So in some cases, for example with some reds, you might be looking at 1 coat gray, 2 coats red, as opposed to 4 or 5 coats red. Then it makes a difference. You would normally have a clue when you would want to do this based on the manufacturer's recommendation for a gray primer.
But putting on an extra coat of finish paint as opposed to the beginning coat of primer really doesn't make much or any difference. In some cases it would actually be more expensive to coat with 1 coat primer and 2 coats finish paint than 3 coats finish paint.
Old 10-06-2013, 12:09 PM   #15
And the added cost and time of another paint setup and clean up.
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
Painting pine - primer? marliz Painting 17 12-12-2010 07:37 PM
Painting Kitchen Cabinets, Back wall NewlywedKristin Interior Decorating 12 03-18-2010 10:23 AM
painting dark from light, how many primer coats? Miss Molly Painting 6 05-20-2009 10:04 AM
Is it normal for primer to show thru dark paint on first coat? Autumnknight Painting 5 10-02-2006 06:38 AM
