Painting Crown Moulding - Painting - DIY Chatroom Home Improvement Forum
Old 02-29-2012, 04:26 PM   #1
painting crown moulding
Do I paint the moulding before I install or after?
16kennedy is offline   Reply With Quote
Old 02-29-2012, 04:29 PM   #2
Too Short? Cut it Again!
You will get differing opinions on this but you might as well paint it when it is off if you have the room. Then nail it in place. Caulk the edges and fill nail holes. Touch up the trim once installed.
Then cut in the wall color to the crown.
Old 02-29-2012, 04:29 PM   #3
Rewards Points: 13,300
A lot easyer to prime and paint it before.
Then you only have to do touch up painting.
Old 02-29-2012, 09:45 PM   #4
ltd
Rewards Points: 536
if you really want to do a pro job and this is part of an over all paint job ,install it first. you can mabey run a coat of primer before you put it up but its not a big deal either way.ok now its up and primed. fill in your nail holes with spackle .i like ready patch,then caulk in all the gapes, i like sherwin williams 950 A caulk. sand the nail holes you filled then spot prime nail holes you patched.give the crown a very light sanding with fine paper do not remove any primer,just very lightly then dust off. your finally ready to start painting .cut and roll your ceiling and feather some of the ceiling flat paint on the crown very lightly do not leave a ridge of paint .the key word is feather.then paint your crown and feather some crown paint onto wall again key word feather.then paint your walls. typically the ceilings are flat , crown and trim is semi gloss, and walls are flat or satin. something i have been doing lately is running the flat ceiling paint on the crown, i know its not typical but it really gives a good look
ltd is offline   Reply With Quote
The Following 2 Users Say Thank You to ltd For This Useful Post:
ben's plumbing (02-29-2012), Workaholic (02-29-2012)
Old 02-29-2012, 11:12 PM   #5
Workaholic's Avatar
The problem with this is that the sheen for trim paints is higher and just touching up nail holes do not often blend in and are rather noticeable when looking at them with blinds open or lights on.
16
I would do a ltd suggested.
Sean
Workaholic is offline   Reply With Quote
Old 02-29-2012, 11:27 PM   #6
Rubbin walls since'79
Brushjockey's Avatar
This was extensively explained to Joe before, but I guess he likes to have people have woodwork that flashes. He keeps saying the same things.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 02-29-2012, 11:28 PM   #7
Workaholic's Avatar
I don't get on here as much as other sites. Now I know.
Sean
Old 02-29-2012, 11:32 PM   #8
Rewards Points: 582
when we do crown we install 1st while its up we can spot nails,fill cracks between crown and ceiling and wall..prime,and paint...
Old 02-29-2012, 11:38 PM   #9
ARC Painting's Avatar
There is no question that you will have to paint them after installation, because you need to fill nail holes and cracks, and paint over those.
You can save a coat by pre-painting, but you'll still need to get up on a ladder...
Toronto Painters, House Painting
Facebook: ARC Painting Toronto
ARC Painting is offline   Reply With Quote
Old 03-01-2012, 05:40 AM   #10
Joecaption, we're here to teach people how to paint, not to teach new construction cost cutting tips, especially ones that will result in a new construction result. Teaching people to prefinish trim before install and touch up after is pure hack, there I said it. I'm all for tips and tricks, but skipping required steps and deviating from standards isn't among the ones I prefer. If you want to sell your snake oil, go to a general contractor forum, somewhere where it will be appreaciated.
If you have raw wood, prime it on the ground by all means, that's an acceptable shortcut. But once it's primed it needs install where it can be caulked to the wall/ceiling, as well as any other wood joins. Then it gets puttied, which requires two coats to properly cover without flashing. (Actually, putty first, then caulk) As Sean pointed out with touch-up, I'm sure that on close examination, or in the right light, your brand of finishing probably looks like a rampant, horrible case of measles. Among the pro painters, of which I don't consider you, you have no supporters. Please drop that certain recommendation from your repetoire, and respect the consensus.
The Following 4 Users Say Thank You to jsheridan For This Useful Post:
ben's plumbing (03-01-2012), chrisn (03-01-2012), Mr. Paint (03-01-2012), Nailbags (03-01-2012)
Crown Moulding Paint Peeling ryanb4614 Painting 6 01-23-2012 10:15 AM
Painting Crown Moulding LeviDIY Painting 3 08-18-2010 02:28 PM
Crown Moulding and nailing davis_mc Carpentry 21 01-12-2010 11:52 PM
Painting MDF crown moulding sk8z Painting 3 05-19-2008 05:11 PM
crown moulding painting WorkOnIt Painting 3 06-18-2007 11:56 AM
