Painting Coving - Painting - DIY Chatroom Home Improvement Forum
Old 05-12-2012, 06:49 AM   #1
Painting Coving
Hi.
Whats the best paint for painting coving. Its been painted before so should be sealed.
fithawk is offline   Reply With Quote
Old 05-12-2012, 11:31 AM   #2
Rewards Points: 13,260
If your talking about cove moulding then any quality acrilic latex paint will work.
Make sure to just clean it first.
Old 05-12-2012, 01:14 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
Most the time cove is painted with a trim paint- a satin or semi gloss.
If it is presently painted with a hard shiny paint- sand it lightly to dull the shine for adhesion.
If you know the paint is an oil enamel, and you are going to a waterborne finish, I recommend also priming it with a good adhesion primer after sanding. A good grip is really essential- and the first thing to hit it is what will give that.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Painting / Coating Laminate Counter top? Kitchen Cabinets ctandc Painting 1 09-29-2011 11:42 AM
painting exterior door JP79ST Painting 18 05-18-2010 05:04 AM
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 06:52 AM
Help! Painting problems on my finished garage mad dog Painting 7 07-23-2009 05:19 PM
