Painting A Countertop And Cabinets... - Painting - DIY Chatroom Home Improvement Forum
Old 03-16-2008, 03:33 PM   #1
Electrician
Question
Painting a countertop and cabinets...
I am gettin ready to close on a townhome and am wanting to paint the countertop and cabinets in the kitchen to help save some time and money..
Has anyone done this before?? Any advise would be very helpful.. Thanks
whutitdew25 is offline   Reply With Quote
Old 03-16-2008, 08:10 PM   #2
Rewards Points: 506
I would not paint the countertop if I were you. It is VERY hard to get the finish to both stick and not contaminate your food. If the countertop is worn out, some kitchens can be fixed up with the pre-cut laminate from BigBoxCo. Otherwise, a local countertop place can put on some custom-cut laminate. (Don't contract for that at BigBoxCo; they will just sub it out to a local place, and charge extra on top of it.)
As far as the cabinets go: Clean w/ TSP, rinse, scuff-sand, prime w/ oil-base primer, topcoat with Waterbourne ProClassic from Sherwin or Waterbourne Impervo from Benjamin Moore. For more application details, search for "ProClassic" on this board.
SirWired
sirwired is offline   Reply With Quote
Old 03-16-2008, 09:15 PM   #3
Tired, Cold, and Damp
slickshift's Avatar
To properly "paint" the countertops you would have to use an epoxy
It will not save much, if any, time and/or money
The proper materials are expensive, and the application process intense
slickshift is offline   Reply With Quote
Old 03-17-2008, 06:20 AM   #4
Rewards Points: 506
When we were preparing to move, we had one of those countertop restoration places give an estimate. They used a sprayed-on epoxy with some kind of stone-colored flecks in it to make it look like a solid-surface. It was going to end up costing more than just replacing the countertop with entirely new laminate. This is extra-odd, because our counter was a funny shape, and cost quite a bit more to have done than most kitchens.
SirWired
Old 03-23-2008, 09:55 PM   #5
painting countertop and cabinet
I agree that this is not an easy or fun job. You're better off buying an inexpensive laminate countertop and perhaps having cabinets refaced. Much fewer headaches!
Allison1888 is offline   Reply With Quote
Do I need a new box? pcampbell Electrical 20 01-07-2009 06:16 PM
Sink for 18" depth cabinets BasenjiMom Plumbing 1 02-10-2007 09:07 PM
Need opinions on toe kick under cabinets kestut Remodeling 4 12-05-2006 04:02 PM
How to mount cabinets on a crooked floor? Hushpuppy Carpentry 19 10-02-2006 12:20 AM
Tiled Kitchen Countertop forcheck Remodeling 3 02-21-2006 07:46 PM
