Old 10-16-2007, 04:11 PM   #1
Painting concrete w/cutback adhesive on it
I have a furnace room that has the 9x9 tile on the floor. They are damaged, and need to be replaced. The problem is under the tile is black asphalt cutback adhesive. I can scrape it down and remove most of it, but the residue remains. Is there a paint or paint/primer combo that will stick to this? Thanks
Mikon is offline   Reply With Quote
Old 10-16-2007, 06:05 PM   #2
Pro Painter
Does a flooring adhesive remover work?
Also, not sure of which paint to use on this. You would use a water product since we don't know if it was "cutback" with a water or petroleum.
joewho is offline   Reply With Quote
Old 10-16-2007, 06:11 PM   #3
Thanks, I'll check into that, do you know if they're flammable? Paint thinner works, but the smell, and the small room with a water heater in it (gas) doesn't make it a good choice.
Old 10-16-2007, 09:27 PM   #4
Pro Painter
Look around the local HD or other big store. You may find something non-flammable.
Plain paint thinner isn't very flammable, just blow out the pilot lights and use ventilation.
Cleaning adhesive from a concrete subfloor sparinaa Flooring 3 09-07-2011 01:11 AM
new concrete floor next to old concrete floor mattroos Building & Construction 10 08-28-2007 02:32 PM
painting concrete victor Painting 3 08-06-2007 10:44 PM
Adhesive removal from concrete sod Flooring 3 04-02-2007 09:41 PM
Painting concrete TerryL Painting 2 12-04-2006 10:17 PM
