Painting Concrete Flowerbed Wall - Painting - DIY Chatroom Home Improvement Forum
Old 03-31-2012, 04:31 PM   #1
painting concrete flowerbed wall
Wanting to repaint a concrete flowerbed wall but seems to stay wet in one spot and moss grows there. Any suggestions as to how to seal a wet wall so I can paint it?
champange dream is offline   Reply With Quote
Old 03-31-2012, 05:34 PM   #2
Rewards Points: 12,882
Use Dri-Loc.
Old 03-31-2012, 05:55 PM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 150
Nothing is going to stick until the moisture problem is fixed.
chrisn is online now   Reply With Quote
Old 03-31-2012, 09:33 PM   #4
Rewards Points: 14
Rubber membrane
can go on opposite side of wall and paint rubber membrane on wall.
davvid20120 is offline   Reply With Quote
Old 04-02-2012, 10:10 AM   #5
Rewards Points: 394
A liner on the flowerbed side is the only method of prohibiting water ingress through the block. I don't believe that UGL drylock is for exterior use, nor will it work properly in this situation.
Will22 is offline   Reply With Quote
Old 04-02-2012, 06:10 PM   #6
chrisn's Avatar
Rewards Points: 150
Seal Siding to Concrete Wall? stevex Building & Construction 3 08-07-2011 07:46 AM
Bathroom Remo: Is this Plaster over Concrete Block? Mounting Backerboard over top? itcanadian Remodeling 10 03-21-2011 01:06 PM
Finishing Basement Wall - Stairs Along Concrete Rob1976 General DIY Discussions 5 02-02-2011 09:39 AM
furring strips or 2x4s against concrete basement wall? denemante Building & Construction 15 01-28-2011 04:49 PM
Need help with how to mount porch light to concrete foundation wall wherm5150 Electrical 7 11-16-2010 09:56 PM
