Painting Concrete Driveway - Painting - DIY Chatroom Home Improvement Forum
Old 05-27-2011, 02:31 AM   #1
Painting concrete driveway
Has anyone painted their driveway? If so what do you like and not like about it? Has it been protected from marks as promised by paint?
Laurence is offline   Reply With Quote
Old 05-27-2011, 05:21 AM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
H[C solid concrete stain will work on a drivewy. It can be found at Sherwin Williams. There is no paint that will withstand hot tire pickup, only epoxies and stains
housepaintingny is offline   Reply With Quote
The Following 2 Users Say Thank You to housepaintingny For This Useful Post:
Gymschu (04-30-2015), Laurence (06-16-2011)
Old 06-17-2011, 12:00 AM   #3
I had a look at H&C and as you have stated they do not promise any resistance to Tyre marks.
Found one product CONCRESHIELD X that promises 'resistance against tyre marks" but not sure if that is just clever marketing. Have you heard of this product/used it?
Old 06-17-2011, 04:52 AM   #4
Too Short? Cut it Again!
Stained concrete can look nice if done by a pro with experience and familiarity with what to expect and how to work with it. I don't see staining something so expansive as a driveway a DIY project. Too much can go wrong.
If you wanted a glossier look or something? You could polish the concrete after it is stained.
I would never paint a driveway even with something claiming resistance to tire marks. First off, "resistance" becomes very subjective in such language?
I guess a sprayed on epoxy finish with products intended for outdoor use could work but the cost might be prohibitive. And at the end of the day a drive goes through lots of temp and humidity changes, is going to crack and the epoxy layer will fracture along with it. The UV rays will bleach color from just about anything over time. It will be difficult to ever match up a repair unless you stick with basic color and pattern. I think that much resin in a natural landscape might look out of place as well.
Years ago my color consulting company did a fair amount of work for an auto dealership and I specified good old porch and floor paint for sections of concrete that were going to display cars outside the showroom. Worked out fine and we just assumed we would have to touch up or repaint the sections periodically. It was not subjected to hot tires, engines, transmissions and so forth though.
You might go online and explore some of the concrete finishing sites. Many have contractor locating services and perhaps a consult with someone in your area would be a good idea before you get too far into this. I should think a responsible contractor would guide you through how much of a project like this you should try to handle on your own?
Old 06-17-2011, 07:49 PM   #5
Gymschu's Avatar
Rewards Points: 836
The problem with painting a concrete driveway is legion. Hot tires, tire marks, slippery surface, gets scuffed up by snow shovels, I could go on and on. As HPNY and sdsester stated, concrete stain would be the way to go. It will still get marked up but will last longer than paint on concrete.
Gymschu is online now   Reply With Quote
Old 06-18-2011, 03:17 AM   #6
It would probably hard to justify the cost but if you polished the concrete after staining you would have a very nice, low maintenance surface. I have seen some drop dead gorgeous polished interior concrete floors. Owners seem to love the zilch maintenance.
At the end of the day you are still going to end up with just a driveway. How much do you want to sink into this project?
Old 04-30-2015, 09:59 AM   #7
Rewards Points: 2
is there a way to use solvent or oil base paint over existing water base paint on a driveway
strech65 is offline   Reply With Quote
3" gap between concrete driveway and concrete garage floor - help! frankrizzo Flooring 0 11-23-2010 08:07 AM
Fencing installed on Concrete Driveway LAkinsharley General DIY Discussions 5 10-20-2010 07:01 PM
Concrete driveway with rock salt finish? imola ghost Building & Construction 11 10-27-2008 12:11 AM
Concrete Driveway Resurfacing? srssrs Building & Construction 8 10-26-2008 08:56 PM
pouring a concrete driveway drewhart General DIY Discussions 20 08-01-2008 03:30 PM
