Old 12-21-2012, 08:29 AM   #1
Painting in cold weather
I am about to finish some kitchen cabinets that I built. Last step is priming and painting. The primer and paint both say to use at temps above 50.
My garage is insulated but definitely gets colder than 50 at night (temps here in NC will be in the high 20's and mid 40's the next few days).
I see on the bottle of floetrol that I've been using that it extends drying time (or allows you to paint) in colder (or hotter) temps. So my question is has anyone used this product for the purpose of painting in cold temps and do you see any problems in doing so?
Thanks,
Rut
rutledj is offline   Reply With Quote
Old 12-21-2012, 12:55 PM   #2
Gymschu's Avatar
In all honesty I would avoid painting in temps below 50. Now, having said that, yes, I have painted in cool temps in a garage or storage building. If it's cool the main thing is to keep air moving with a fan so the cabinets dry. If the air is not moving you have a great chance of condensation moisture building up on the paint film.
So, if you can avoid doing so don't do the painting now........but, if your on a time schedule, take precautions and proceed with caution.
Old 12-21-2012, 03:44 PM   #3
I agree with Gymschu. Maybe you could rent a commercial portable space heater for a couple of days. Anything that significantly speeds up or retards the drying process could have adverse affects.
Old 12-26-2012, 09:00 AM   #4
Adding warmth and ventilation would be best. Adding Floetrol provides no benefit to painting in colder temperatures- it is not ethlene glycol (anti-freeze).
Will22 is offline   Reply With Quote
The Following User Says Thank You to Will22 For This Useful Post:
cdaniels (12-28-2012)
Old 12-28-2012, 01:36 PM   #5
cdaniels's Avatar
Keep the temp. over 50 for at least a few hours after you finish putting the primer/paint on and you won't have any problems.
cdaniels is offline   Reply With Quote
Trane unit not switching from heat pump to Furnace when weather gets cold. Jimw606 HVAC 1 09-27-2011 05:03 PM
Garage Fridge Tripping Breaker in Cold Weather aaronjwood Electrical 10 12-24-2010 07:47 PM
Kitchen Faucet Cold Water Runs Hot Mthrboard Plumbing 8 08-02-2009 07:59 AM
Cedar Decking and Cold Weather project_guy Building & Construction 3 01-29-2009 06:32 AM
Painting in the cold!!! jhm Painting 1 02-22-2004 07:38 PM
