Painting Coffee Tables?? - Painting - DIY Chatroom Home Improvement Forum
Old 03-28-2008, 09:06 PM   #1
Ok... so I have these two coffee tables made out of particle board with a wood-like finish that I would like to paint. What would be the best type of paint to use? Should I sand or prime the tables first?
My dad is a construction painter and says that I shouldn't bother trying to paint them because it will just bubble and not work right. Is this true??
Deesiebop is offline   Reply With Quote
Old 03-28-2008, 09:25 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
Well, he's got a point
If it's the cheapo knock-down (you assemble) stuff, it's basically a picture of wood "laminate" glued to particle board
If you use a latex primer, it will bubble
You could do a quick, light coat of a solvent based primer and it might not affect the glue
If it's the slightly better than paper fake wood laminate, you'd still need to use a solvent-based primer
Lightly sand, if you can w/o messing up the laminate, and then dust before priming
slickshift is offline   Reply With Quote
Painting over a sponge painted wall Snowdog Painting 3 03-16-2008 11:13 PM
Painting a room different colors carldjensen Interior Decorating 5 11-08-2007 08:49 AM
Painting Exterior Spruce Rough-sawn trim questions Stonemeel Painting 8 09-11-2007 07:00 AM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
Hairline Cracks after painting parasailing Painting 8 07-23-2006 11:47 PM
