Painting Cira 80"s Rough Interior Trim - Painting - DIY Chatroom Home Improvement Forum
Old 08-20-2011, 01:17 PM   #1
Painting cira 80"s rough interior trim
I am getting ready to tackle all of the wood trim in our condo. It looks like it could be cedar but I am not sure. It has never been stained or trated since the condo was built. It is rough and ugly. I am not ready to replace all of the trim yet, but I can't stand the dark trim around everything. The wood is so rough it will give you splinters. I am at a loss to where to begin. Do I try a little sanding, or just go for priming it. I am guessing I should use a oil base primer for this. Any help or suggestions would be helpful. My Dad tough me so much, but this gal has not tackled any wood trim that is as ugly as this is.
PGirl is offline   Reply With Quote
Old 08-20-2011, 01:39 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
Cedar is usually not used as interior trim- Can you take a pic and show us?
( Might have to host it and link..)
Brushjockey is offline   Reply With Quote
Old 08-20-2011, 01:42 PM   #3
m1951mm's Avatar
If you whole condo/home is this way, please do yourself a favor and do one room or two if you are ambitious at a time. You will first need to sand down the trim, give it a coat of an oil primer, and sand again prior to even thinking about a finish coat. Anytime you sand between coats it is just as important to clean off the dust as the actual putting on of the paint
Now that I think about it, putting in new factory primed trim does not sound so bad. I understanding wanting to save the old, but when you look at the trim and all the little in's and out's that you have to sand, prime, and possibly sand and prime again to make it RIGHT, putting in new makes sense to me. Dollars are one thing, getting it to where you want it to be are on a different plane.
Please let the other contributors on the forum know what your final hope is, that way you will get better information. Good Luck
Mickey
Fantasy Walls and Windows
www.picturetrail.com/mickey51
m1951mm is offline   Reply With Quote
Old 08-20-2011, 08:30 PM   #4
I would use Zinsser BIN shellac based primer, for two reasons. If it is bleeding wood, you'll be covered. Secondly, it will help encapsulate the roughness better than oil and leave a smoother finish. I would first run some 80 weight sandpaper over the whole surface. Dust it off well, then prime.
Old 08-20-2011, 08:53 PM   #5
NACE Coating Inspector
mustangmike3789's Avatar
yes, pics of your trim would be nice
mustangmike3789 is offline   Reply With Quote
Old 08-20-2011, 10:23 PM   #6
ltd
Rewards Points: 536
is this a rustic look in your condo. ruff sawed lumber ? if it is your talking bout belt sander obertal sander type prep.with out seeing a pitcher im only guessing . you can paint over rustic trim ,zinnzer cover stain oil primer then 2 coats latex semi or satin
ltd is offline   Reply With Quote
Painting rough plaster somuchjackson General DIY Discussions 6 07-25-2011 11:54 PM
Painting a red brick fireplace with rough brick exterior LoriDebi Painting 1 05-06-2011 12:21 AM
Slightly rough after spray painting colinmc8 Painting 8 06-07-2010 11:33 AM
Painting rough Plaster deck hand Painting 4 11-29-2008 06:47 PM
Painting Rough Pine is it possible rdalrymple Painting 7 11-24-2008 08:57 PM
