Old 06-04-2007, 01:20 PM   #1
Painting Chair for Nursery
I am painting a wooden chair to go in our nursery. The chair has been sanded to take down the glossy finish. It has a few decorative spindles. Would it be best to spray paint it or brush it on?
Since it will be in a nursery, do I need to paint with any special paint? It is not like the baby will be eating the chair . comments?
cibula11 is offline   Reply With Quote
Old 06-04-2007, 01:34 PM   #2
How can you be sure there will no gnawing or chewing? I was asking about paint for a counter top at Lowe's and was told they had nothing FDA approved for that application.
Old 06-04-2007, 01:39 PM   #3
I can't guarantee anything. I was just thinking if using regular paint on a chair was not safe, then how could anyone with children justify anything in their house being painted i.e, walls, cabinets, furniture, baseboard...... Unless someone posts different, I guess I'll go ahead and use the paint.
Spray or brush comments?
Old 06-04-2007, 06:53 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
No special paint
Pretty much anything on the market today will be OK
A waterborne enamel will give you the best finish
Latex enamel would be a second choice
(technically they are both water-based and therefore latex, but there is a difference in quality)
Spray or brush is a tough call
If you don't have a sprayer, renting one would be cost prohibitive for one chair
A premium brush is a bit more cost effective
slickshift is offline   Reply With Quote
Old 06-04-2007, 07:11 PM   #5
The chair will be white. Is there a good can spray paint that would give a good finish?
Old 06-04-2007, 10:58 PM   #6
slickshift's Avatar
No
But if you have a good Paint Store, they may have a little sprayer that sits on top of a jar and uses little gas capsules as propellant
I've never used them for enamel...but maybe you could ask them at the store if it'll work
I'm not sure it would give you a "better" finish
It's really a spot/touch-up type deal
..and I personally like a few brush marks on my rockers
Gives them a a little personality...a personal touch
Old 06-05-2007, 07:48 AM   #7
poppameth
Guest
Posts: n/a
Those little spray units are junk. Get a can of Krylon contractor series with the adjustable tip on it if you want a decent budget spray. Those units you put your own paint in sputter and spit if they spray at all.
Old 06-05-2007, 10:58 AM   #8
So, if it were you, would you
1. spray it
2. brush it
(I guess both with white enamel paint)?
Old 06-05-2007, 11:02 AM   #9
Okay, I know using latex paint will probably start to chip off. If I paint with latex and then use a spay lacquer over that, would that work? I have a quite a bit of white latex I would like to use.
Old 06-06-2007, 05:39 PM   #10
slickshift's Avatar
IMHO that's not a good idea
Better to use the correct product that works well, once, then try and use a product that won't work well, and make extra work and cost by sealing it it with another product...that isn't designed for sealing in an ill adhering product anyway...
Old 06-07-2007, 03:28 AM   #11
Pro Painter
Krylon has a new paint called H2O that comes in a spray can and advertises that it bonds on a molecular level. I haven't tried it, but it sounds like it would fit your purposes. It is water based.
Spray the chair. I've painted and stained quite a few chairs, they are some of the most difficult pieces to do with a brush.
joewho is offline   Reply With Quote
Old 06-08-2007, 10:39 PM   #12
Workaholic's Avatar
If i was you i would brush it since it is just one chair. Now if you do not own any brushes then a rattle can might be better. I would still brush it.
Workaholic is offline   Reply With Quote
More On This Topic
Paint for Roof Eaves
Paint for Roof Eaves by Expert Village
Hello! My name is Grady Johnson and I'm a professional painter, and today I represent expertvillage.com. Now we're going to talk a little bit about choosing paint. This is very important. When you're painting your exterior eaves, there are really only a... Read More »
There are a number of different ways to use lattice in and around your home. Lattice can be bought in unfinished wood or expensive colored vinyl. If you have a special color or don't want to spend money on the colored vinyl, you can paint wood lattice... Read More »
Hello! My name is Grady Johnson and I'm a professional painter, and today I represent expertvillage.com. Now we're going to talk a little bit about the materials we're going to need to paint the exterior eaves on our house. Now, whenever you're painting... Read More »
Painting the Trim
Painting the Trim by Expert Village
ealealOk, the final step in our bedroom painting project is to paint the trim. We already painted the walls with the flat paint and that's dry so we're going to go ahead and apply the trim paint which is going to be a semi-gloss which is essentially... Read More »
Stencils: Decorating Chairs
Stencils: Decorating Chairs by Expert Village
Hi this is Brenda and today we are stenciling on a metal folding chair. The first part of our project is to decide which stenciling template we are going to use. This has several on it. This sheet does so I believe today I am going to choose the little... Read More »
DIY Chair mat from plywood and carpet tiles jbwaechter Flooring 3 08-20-2009 08:29 AM
Garage drywall painting haylo75 Painting 18 11-12-2007 10:13 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 04:33 PM
I need to build a stand to hang a chair xray328 Carpentry 2 03-31-2007 11:31 AM
Hairline Cracks after painting parasailing Painting 8 07-24-2006 01:47 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
