Painting Ceramic Tiles - Painting - DIY Chatroom Home Improvement Forum
Old 04-28-2011, 02:43 PM   #1
Painting ceramic tiles
Anyone had any luck painting ceramic bathroom tiles? Mine are pink and would like to change before selling house but not spend alot of money. I don't mind painting if it works and looks ok. Thanks
SamB is offline   Reply With Quote
Old 04-28-2011, 04:26 PM   #2
Gymschu's Avatar
Rewards Points: 184
It can be done although I don't recommend it for too many reasons. A quality bonding primer (one that will stick to glass) would be step one. Allow to dry for 24-48 hours and then topcoat with your finish coats. The problem with hard surfaces like tile is that anytime you bump it or hit it you are bound to knock some paint off.
Gymschu is online now   Reply With Quote
Old 04-28-2011, 04:44 PM   #3
the Musigician
DangerMouse's Avatar
The problem too with painting tile is it will look like.... well... painted tile!
Not a big selling point.
DM
Old 04-28-2011, 05:28 PM   #4
I don't think getting rid of the pink is going to be accomplished without dropping a few bucks, with paint or tile replacement. Gymschu is correct in that it could be painted and would probably hold up pretty well. There's usually not too much banging around in a bathroom. But dangermouse is correct in saying that it would look like painted tile. Once the tile and the grout are the same color, it's going to look solid and crappy. However, with a little patience and skill, it could be pulled off. I would suggest painting/decorating in a fashion that complements the pink tile and makes it look like that was the plan, and takes the apology out of it.
Old 04-28-2011, 06:09 PM   #5
Learning by Doing
Leah Frances's Avatar
Use the 'search' bar on the site. Use the terms 'painting tile' this is a well discussed topic.
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
The Following User Says Thank You to Leah Frances For This Useful Post:
SamB (04-28-2011)
Old 04-28-2011, 06:23 PM   #6
Thank you Gymschu, DangerMouse, and jsheridan for your replies. Guess I'll just go the decorating route (which I kind of already have anyway). Pink is still pink though! Thank you!!
Old 04-28-2011, 07:25 PM   #7
the Musigician
Make it as nice as you can, and maybe you'll get lucky and find some gal that WANTS a pink bathroom! Po)
DM
Old 04-28-2011, 07:54 PM   #8
DangerMouse,
One can only hope! Thanks.
Laying dura ceramic tiles on concrete monte Flooring 25 03-11-2013 10:31 PM
Re-tiling a bathtub surround BillyB44 Remodeling 39 01-24-2011 07:10 PM
Need to replace 4 3x3 ceramic tiles around shower. babaganoosh Tiling, ceramics, marble 1 12-28-2010 09:40 PM
stains on ceramic tiles bubby :-) Tiling, ceramics, marble 1 06-24-2009 02:05 AM
Difference between difference ceramic tiles J187 Building & Construction 6 03-04-2009 01:17 PM
