Painting Ceramic Tile - Painting - DIY Chatroom Home Improvement Forum
Old 06-16-2007, 08:03 AM   #1
Diesel Fitter
Rewards Points: 150
Painting ceramic tile
I need some info, Thank You.
1) What type of paint, and can I thin it?
2) Tile prep., should I acid wash, and what type acid/cleaner?
3) Grout, can I remove it and replace after paint, or should it be prepared and painted with the tile?
4) Can I use a low pressure high volume sprayer?
Thanks again, Mike
mikemy6 is offline   Reply With Quote
Old 06-16-2007, 10:02 AM   #2
Tired, Cold, and Damp
slickshift's Avatar
Some Qs for you Mike
Floor or wall?
Why do you want to paint tile?
It's not easy to keep the paint on ceramic tile
And really not recommended
If it's for a floor I wouldn't even hope it'll stay long
If you really want to attempt it, it'll be sanding for prep, a specialty bonding primer, then brush and roll the paint on, two coats
But I wouldn't recommend it...unless you've got some unusual circumstances there
slickshift is offline   Reply With Quote
Old 06-16-2007, 11:09 AM   #3
Guest
Guest
Posts: n/a
For walls, lightly sand the tile to knock the gloss off. Then apply Zinsser BIN primer and two coats of paint. BIN is the best thing I've found to adhere to ceramic. I also wouldn't attempt it on a floor.
Old 06-19-2007, 03:25 AM   #4
Diesel Fitter
Rewards Points: 150
Thanks Slick and Poppa
I will be installing new floor tile, but couldn't get them to bite on the walls.
It's 2 8'x8' open ended shower walls 4''x4'' tiles.
Old 06-19-2007, 07:31 AM   #5
slickshift's Avatar
Originally Posted by mikemy6 View Post
...couldn't get them to bite on the walls...
It's for someone else?
No warranties on that then
Put this in writing - make them sign it
On walls, with the BIN, it might last for a while
But still - waiver it
Those Home Makeover shows never come back 6 months later when the tile paint-over has failed
Customers think it's an easy, cheap, permanent fix
It's not
Well, like I said, it could last a while
Old 06-19-2007, 09:23 AM   #6
Guest
Guest
Posts: n/a
I've had one lady do this with BIN and Accolade. I've talked to her about a year after the project and it was still doing fine. That's no guarantee though. Just because it works once doesn't mean it's foolproof.
Old 06-19-2007, 04:32 PM   #7
Diesel Fitter
Rewards Points: 150
Thanks Everyone
They are going to mirror the walls now, Thank God. Its at an adult club for shower shows so everyone will get a good view from all sides now!
Thanks again
Mike
Old 06-19-2007, 08:27 PM   #8
Guest
Guest
Posts: n/a
Yeah mirrors would be much better for that!
Old 06-22-2007, 06:50 PM   #9
Diesel Fitter
Rewards Points: 150
And how!
Ceramic tile over existing (full mud) ceramic? rjniles Flooring 7 12-24-2008 07:12 PM
stains on ceramic tile sdgoss Flooring 4 09-19-2008 07:19 PM
Preping for ceramic tile install leroyme Flooring 21 11-29-2007 04:31 PM
ceramic tile painting c39c39 Painting 9 01-04-2007 03:24 AM
Ceramic tile installed over resiliant tile ramsfanjeff Flooring 1 11-26-2005 03:26 PM
