Old 07-20-2008, 03:11 PM   #1
lavee383's Avatar
Painting ceiling and wall (2 diff colors) when both are textured
First off, I apologize in advance if this topic has already been discussed, but I was not able to find it in the search.
I have a two year old home and the ceilings and walls are all textured (orange peel) and are all the same color (light beige/tan). My problem is trying to paint a nice line between the ceiling and the walls.
My wife wants some of the rooms to have the ceiling white and then the walls different colors in each room. We've already tried to paint the laundry room and our master bath, but have come up with the dreaded bleed thru under the tape on the ceilings/trim.
Short of having to go back over everything with a small brush to clean this mess up, is there anything that we can do to first, avoid this problem in the future (technique) and second, what's the best solution to fix our existing mess? I've already tried to run a small bead of calk along the edges, but that just puts calking on the different colored wall which means I have to go and brush along the edge to cover it up.
Am I making any sense?
Any help at all would be appreciated.
lavee383 is offline   Reply With Quote
Old 07-20-2008, 03:54 PM   #2
Drywall and Painting Pro
Sir MixAlot's Avatar
Try a 2 1/2" angle sash brush.
Checkout some of
Sir MixAlot is offline   Reply With Quote
Old 07-20-2008, 07:00 PM   #3
lavee383's Avatar
thanks...but i'm not sure what you are saying to use it for? cleaning up the mess i've got?
any ideas as to how to avoid this corner problem?
Old 07-20-2008, 09:57 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
I'd suggest a 1" or 1.5" premium angle sash brush for touching it up until it looks OK
Really, there's no better way
...actually no other way realistically
For the future, the best way is a premium paint, a premium brush, and a steady hand
Tape, as you have seen, can cause more problems then it solves when used to cut lines
slickshift is offline   Reply With Quote
Old 07-21-2008, 11:28 PM   #5
lavee383's Avatar
thanks slick...
...anyone else have any ideas?
popcorn ceiling painting phil334 Painting 2 07-12-2008 12:23 AM
Converting wall outlet to power ceiling light? VEIK Electrical 3 07-08-2008 09:43 AM
Bracket to Ceiling mount a Wall mount floodlight Ski Electrical 1 06-27-2008 12:18 PM
Wall to ceiling fw2007 Electrical 4 03-31-2008 07:18 PM
Raising Doorway Height (load bearing?) treefrog Building & Construction 6 02-25-2008 10:11 PM
