Painting Ceiling Problem: - Painting - DIY Chatroom Home Improvement Forum
Old 01-26-2014, 12:25 PM   #1
Rewards Points: 67
Painting ceiling problem:
I'm not a pro painter but have been doing general remodeling and lots of painting for almost 40 years. Have a pretty good grasp of surfaces, prep, tools, paint, application.
I had a local contractor build a small addition, bedroom and bath: they did all the framing, drywalling and mudding, I'm doing the painting. Painted the bathroom ceiling with white latex satin (very small area) absolutely no problem. The bedroom ceiling is giving me fits!
The mud was finished and plenty dry (two weeks). Applied a nice even coat of Kilz 2 White Primer & Sealer using a good quality Purdy 3/8" roller cover. It did not dry with quite the uniform finish that I'd expected, but it's just primer and I assumed that the finish coats would do the trick.
Using a new Purdy 3/8" cover, I applied a good solid coat of BEHR Premium Plus 1-gal. Flat Interior Ceiling Paint from Home Depot, about $24 per gallon. Cross-rolled as I went along, not too much paint and not too little, very careful of roller marks and such: as I said,I've done this once or twice before. Let it dry 24 hours.
The result was very streaky, just looks like tons of roller marks. I got another gallon, applied another coat this time with a Purdy 1/2" cover: used the right amount of paint, cross-rolled as I went along for good coverage, very careful about stop & start roller marks. Same darn result! Just looks streaky & blotchy.
Any ideas or suggestions much appreciated.
oldberkeley is offline   Reply With Quote
Old 01-26-2014, 01:10 PM   #2
Gymschu's Avatar
Rewards Points: 662
One word: Behr.
The Following User Says Thank You to Gymschu For This Useful Post:
HighGlossPL38 (01-26-2014)
Old 01-26-2014, 01:34 PM   #3
Painting Contractor CT
Rewards Points: 77
Post
Use Benjamin Moore or Sherwin Williams ceiling paints instead. Good Luck!
KD PAINTING is offline   Reply With Quote
Old 01-26-2014, 02:36 PM   #4
Jb1234's Avatar
Rewards Points: 87
I agree with the Behr statement. Years ago when I was a novice I used Behr and I fought it the entire time. Got educated and wise, plunked down the cash and got SW. Won't use anything else.
Jb1234 is offline   Reply With Quote
Old 01-26-2014, 03:53 PM   #5
Rewards Points: 5,974
Originally Posted by Gymschu View Post
One word: Behr.
Agree about 3 more coats should do it. Their ceiling paint SUCKS!!!
The Following User Says Thank You to ToolSeeker For This Useful Post:
Gymschu (01-26-2014)
Old 01-26-2014, 04:27 PM   #6
Gymschu's Avatar
Rewards Points: 662
Or if you have a PPG store near you:
Old 01-26-2014, 04:29 PM   #7
Rewards Points: 67
LOL, I hear you guys.
I thought that on top of good primer, and using two coats, it would work. But I have reached the same conclusion: it is sh***y paint!
Just went and got a gallon of Benjamin Moore and a new roller cover, back to it tomorrow morning.
Old 01-26-2014, 04:31 PM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 312
"better to leave the walls bare than put Behr on the walls"
Painting ceiling problem:-behr-20vs-20water.jpg   Painting ceiling problem:-behr1.jpg
chrisn is online now   Reply With Quote
The Following User Says Thank You to chrisn For This Useful Post:
Old 01-26-2014, 09:41 PM   #9
ltd
Rewards Points: 536
its hard to say with out seeing it ,you could have over rolled your paint into paint that was starting to set up giving you lap marks.mabey the sheet rock finish is not as good as you think. Should use a 1/2 nap cover .. one thing I do know is its not the paint .
ltd is offline   Reply With Quote
Old 01-27-2014, 06:38 AM   #10
Please explain How you know this.
Old 01-27-2014, 04:32 PM   #11
chrisn's Avatar
Rewards Points: 312
really????????????????????????
Old 01-27-2014, 04:59 PM   #12
ltd
Rewards Points: 536
chrisn im saying this as not to be a smart azz .but im confident the painters on this site could roll a primer coat then 2 coats behr. we could probly do it in 1 and it would be fine.its not the paint I would use .but to say oh its the paint ,whos to say ,personally I think he put lap marks. but how do I know im sitting here waiting for dinner
Old 01-27-2014, 06:02 PM   #13
Rewards Points: 4,796
The problem with those guys is they're going to say the problem is the paint whether it is or not. And of course you're saying it's not.
Actually I've never used the Ceiling Paint, per se, only the regular paint. So I really have no idea if the paint is any good or not. However I've never had any problems with Premium Plus Ultra on any walls.
The pictures you see above are not of ceiling paint, and therefore aren't relevant.
Comments like the following are worthless:
"Years ago ...I used Behr... Got educated and wise...got SW."
Experience with a paint from years ago is irrelevant - the formulas have changed. Also doesn't mention which Behr paint. SW is not a paint - it's a company. There is no such paint as "SW", so that comment is of no help either.
jeffnc is offline   Reply With Quote
Old 01-27-2014, 06:14 PM   #14
Rewards Points: 89
In my old life I used Behr ceiling pain many times and two coats did fine, never any issues. Now I like BM Super Spec flat. Relatively cheap and blends really well.
7.62 is offline   Reply With Quote
Old 01-28-2014, 02:54 PM   #15
Matthewt1970's Avatar
Rewards Points: 1,098
Yes it does. OP you are seeing the exact reason why Behr gets so many complaints.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Painting ceiling and walls Homerlion Painting 18 12-23-2013 03:36 PM
Painting basement ceiling...drywall first or paint first? jdtox Painting 3 10-15-2012 08:33 PM
Painting or Replacing Canister Ceiling Lights justagirl Electrical 1 07-14-2008 03:38 AM
Trouble installing ceiling light fixtures: same problem x3 sweetroad9 Electrical 5 04-13-2007 01:46 PM
Vaulted Ceiling Insulation Problem casey_wa Roofing/Siding 13 05-08-2006 09:55 AM
