Painting A Ceiling And Partially Down Walls - Painting - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 01:09 PM   #1
painting a ceiling and partially down walls
Using an off-white paint I'm painting a textured ceiling and then carrying the paint about 12 inches down all the walls. The colour of the bottom portion of the walls is a lot darker than the ceiling colour. Do I have to do a line prior to painting the ceiling/walls? or can I just overpaint into the darker portion of the wall, do a line, and then paint the lower portion of the wall with the darker colour?
JeanneSprague is offline   Reply With Quote
Old 11-01-2011, 01:30 PM   #2
Yes, to the second option. You always want an overlap with one color whenever two colors meet. Since painting is done top/down, inside/out, you paint the ceiling first, overlapping, then cut your line to the white. Good Luck with that.
Joe
Old 11-01-2011, 01:52 PM   #3
jschaben
Rewards Points: 502
Since I have experienced attempting to cover light color with a darker color, and, as a DIYer where my time isn't worth near as much as a pro, I would be inclined to paint the ceiling and a few inches down the wall. Paint the dark color and then go back with the ceiling paint to the desired level. JMHO.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 11-01-2011, 04:22 PM   #4
Top/down, the ceiling should be completed first. Most dark colors will go over white, especially a flat ceiling white. It's only the really deep colors with neutral/clear bases that have trouble. I just put a dark brown over white Azek, two coats no problem. SW A-100.
Old 11-01-2011, 04:57 PM   #5
jschaben
Rewards Points: 502
Hadn't really thought about it being ceiling flat. Had a dickens of a time going over Sailcloth with Burgundy. Sailcloth was flat, Burgundy was semi, both Ben Moore Moorgard. I've also had problems covering coverstain primer with McCloskey Hunter Green semi.
John Schaben
Old 11-01-2011, 05:15 PM   #6
paper hanger and painter
chrisn's Avatar
Rewards Points: 230
Joe
Boy, I'm glad YOU understood it.
Snow in attic through mushroom vents,leaking into great room ceiling thom risley Roofing/Siding 17 02-03-2014 04:47 PM
Framing an unfinished basement captainobvious Building & Construction 7 10-16-2009 10:53 AM
Ceiling Fan Repair Stevera64 Electrical 7 08-18-2009 06:34 PM
Advice for installing ceiling fan Ceiling Fan Man Electrical 5 06-02-2009 05:18 PM
Partially finishing basement nrpalm Remodeling 5 02-06-2008 08:15 AM
