-   -   painting a ceiling and partially down walls (http://www.diychatroom.com/f4/painting-ceiling-partially-down-walls-122034/)
JeanneSprague 11-01-2011 01:09 PM
Using an off-white paint I'm painting a textured ceiling and then carrying the paint about 12 inches down all the walls. The colour of the bottom portion of the walls is a lot darker than the ceiling colour. Do I have to do a line prior to painting the ceiling/walls? or can I just overpaint into the darker portion of the wall, do a line, and then paint the lower portion of the wall with the darker colour?
jsheridan 11-01-2011 01:30 PM
Yes, to the second option. You always want an overlap with one color whenever two colors meet. Since painting is done top/down, inside/out, you paint the ceiling first, overlapping, then cut your line to the white. Good Luck with that.
Joe
jschaben 11-01-2011 01:52 PM
Since I have experienced attempting to cover light color with a darker color, and, as a DIYer where my time isn't worth near as much as a pro, I would be inclined to paint the ceiling and a few inches down the wall. Paint the dark color and then go back with the ceiling paint to the desired level. JMHO.
jsheridan 11-01-2011 04:22 PM
Top/down, the ceiling should be completed first. Most dark colors will go over white, especially a flat ceiling white. It's only the really deep colors with neutral/clear bases that have trouble. I just put a dark brown over white Azek, two coats no problem. SW A-100.
jschaben 11-01-2011 04:57 PM
Hadn't really thought about it being ceiling flat. Had a dickens of a time going over Sailcloth with Burgundy. Sailcloth was flat, Burgundy was semi, both Ben Moore Moorgard. I've also had problems covering coverstain primer with McCloskey Hunter Green semi. :(
chrisn 11-01-2011 05:15 PM
Joe
Boy, I'm glad YOU understood it.:laughing:
