Painting At The Ceiling Edge - Painting - DIY Chatroom Home Improvement Forum
Old 09-23-2008, 09:56 PM   #1
Painting at the ceiling edge
I was painting a room in my house and to avoid getting paint on the ceiling put a masking tape on the ceiling. After paint dried a bit I began removing the tape but some of it got stuck to the ceiling and it's very hard to remove it. What's the best way to remove a masking tape that dried to the wall without damaging the paint job?
Also, what is a good technique to paint at the edge of ceiling and the wall?
thanks,
webtekie
webtekie is offline   Reply With Quote
Old 09-23-2008, 10:17 PM   #2
Registered User
Termite's Avatar
I never mask ceilings. The change in plane should be "cut in" by hand with a brush. You just have to go slowly and carefully, and you'll get the hang of it.
I often pull my tape when the paint is still wet to avoid peeling or sticking issues.
Your masking tape probably got paint under it and is now bonded to the ceiling. You just usually can't mask off a ceiling if there's any sort of texture because paint will still get by. If you do mask, don't rely on it as a paint barrier...Use it to keep you in the lines and catch you if you mess up. You'll have to scrape it off and re-paint any boogered spots.
Old 09-25-2008, 01:26 PM   #3
I haven't mastered the cut in with a brush technique, but I have figured out another way (and I'm always looking for better ideas!). I used a straight edge and a "paint edger" (I have popcorn ceilings).
Here's a paint edger, but my fav came from Big Lots...
http://www.sears.com/shc/s/p_10153_1...0070921x00003a
And here's a straight edge (apparently ,the technical term is "trim guide")...
http://www.lowes.com/lowes/lkn?actio...433&lpage=none
I hold the straight edge at an angle where the ceiling meets the wall and press the paint edger up into it. Just watch the straight edge - it has to be cleaned if paint gets behind it. And don't press the paint edger too much into the wall.
Good luck!
Chianti is offline   Reply With Quote
Old 09-28-2008, 07:17 PM   #4
Rewards Points: 518
Pretty much what everybody said, but I've made the mistake of leaving the tape on until the paint was dried in the past. What I did to minimize damage was take a utility knife with a new sharp blade and score the edge carefully.
I have one of the painters edge/trim guides, I find that they tend to bulk up the paint in the corner or edges you're working with and don't act as a guard for sloppiness. It was much easier to take the time to learn how to cut in with a brush. It'll be slow progress at first, but once you get the hang of it and confidence you'll fly through it.
If you must use tape, pull it off while its wet as said above.
n0c7 is offline   Reply With Quote
Old 09-29-2008, 06:47 AM   #5
Rather than using masking tape you could also get the actual painters tape. It's usually green and does not stick hard to paint surfaces, it just peels right off no problem with no worries about pulling off your paint or sticking.
r62ewa is offline   Reply With Quote
Old 09-30-2008, 08:52 PM   #6
Even some of the Painters Tape has a release life leave it on to long and it's hard to remove,
As others have said learn to cut in by hand and buy a good brush like a Purdy for detail work..
gotboost is offline   Reply With Quote
Old ceiling replacement idsp General DIY Discussions 12 07-25-2009 10:48 AM
Painting ceiling and wall (2 diff colors) when both are textured lavee383 Painting 4 07-21-2008 10:28 PM
Painting or Replacing Canister Ceiling Lights justagirl Electrical 1 07-14-2008 03:38 AM
popcorn ceiling painting phil334 Painting 2 07-11-2008 11:23 PM
