Painting A Ceiling - Painting - DIY Chatroom Home Improvement Forum
Old 05-12-2012, 05:42 AM   #1
Painting a Ceiling
I have a large ceiling area to paint.Put one coat on and patchy or missed areas. How do I get a good uniform coat? and with what equipment? Its medium artex.
fithawk is offline   Reply With Quote
Old 05-12-2012, 11:11 AM   #2
Rewards Points: 13,968
No pictures so I'll guess it just needs a second coat.
DO the cutting in first (hand painting the edges) then use a 1/2 nap roller.
No clue what artex is.
Old 05-12-2012, 12:28 PM   #3
Rubbin walls since'79
Brushjockey's Avatar
Artex I believe is what is called a "popcorn" texture, right?
You need a 1/2 roller, and use plenty of paint. THe biggest mistake most HO have is being too stingy with the material.
Roll 90 deg. from direction as last time. You are using an extension pole, right?
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
Gymschu (05-12-2012)
Old 05-12-2012, 12:52 PM   #4
dogris's Avatar
You're using flat paint I presume. I would use no less than a 3/4" nap cover. Depending on the roughness of the popcorn and ceiling sq ft I might use up to 1-1/4".
The larger naps help you be more liberal in paint application. Brushjockey is right about not being stingy.
dogris is offline   Reply With Quote
Popcorn Ceiling Painting. How? kennykenny Painting 7 01-04-2012 06:28 PM
painting wood fiber ceiling tile sys72db Painting 4 09-25-2011 01:19 PM
painting a sand-textured ceiling? diy'er on LI Painting 1 03-30-2010 08:22 AM
Bathroom ceiling painting not-real-handy Painting 5 08-23-2009 05:30 PM
Painting a textured ceiling computerdude103 Painting 4 06-28-2009 11:43 AM
