#1 |
Painting cast iron pipe that is already black
Hi
SO we have a cast pipe in a room, it will be removed soon, however at the moment its black (some sort of paint already on it, its gloss), i need to paint this to "blend in" to the room as we removed the box (doing the walls). Whats the best paint to use or will any wall paint do? Many Thanks Ashley |
#2 |
If the pipe will be removed soon, just give it a quick sanding, dust it off and put whatever wall paint on it that is currently on the walls. If any rust spot prime with oil primer, spray can or brush.
To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. |
| Display Modes | |
| Painting a cast iron baseboard | secutanudu | Painting | 10 | 03-22-2010 10:23 PM |
| running black gas pipe | lukeg | Plumbing | 6 | 10-25-2009 12:16 AM |
| pvc to cast iron hub using fernco-can't get it! | What have I done | Plumbing | 5 | 08-21-2009 09:44 PM |
| working with cast iron | ericadami | Plumbing | 9 | 11-30-2008 01:45 PM |
| Help with Cast Iron | Material Tester | Plumbing | 2 | 10-25-2007 11:58 AM |
