Painting Carpet - Painting - DIY Chatroom Home Improvement Forum
Old 08-31-2007, 02:31 PM   #1
Painting Carpet
Does anyone know if you can spray paint throw rugs?
Susie Q is offline   Reply With Quote
Old 08-31-2007, 02:43 PM   #2
Tired, Cold, and Damp
slickshift's Avatar
You can spray paint anything
...but the better way to change the color of fabrics is to dye them
slickshift is offline   Reply With Quote
Old 08-31-2007, 02:48 PM   #3
Spray paint
How long would it take for a sun porch carpet outside in 90 degrees to dry?Will it dry hard?
Old 08-31-2007, 02:51 PM   #4
Rewards Points: 150
Are you still trying to spray paint it? If dying, drying should take only a few hours on a nice day if hung out to air dry.
If spray paint... no idea as I've never seen anyone do it... although it may end up looking like art...
slakker is offline   Reply With Quote
Old 08-31-2007, 07:03 PM   #5
made in U.S.A.
Hamilton's Avatar
That's funny!
People sleep peacefully at night because rough men stand guard to deal with violence on their behalf.
Hamilton is offline   Reply With Quote
Old 08-31-2007, 08:16 PM   #6
Susie Q,
Please do not paint your carpet. The neighbors might call the guys in the white suits. And they won't be fellow painters.
Big Bob is offline   Reply With Quote
Old 08-31-2007, 10:39 PM   #7
Guest
Guest
Posts: n/a
You must have seen one of the several hundred shows on HGTV where they did this. You'd be better off to use an acrylic paint if you are going to do it (Krylon H2O if you want to spray it) as it will be more flexible when dry. Paint is actually the better was to go with this particular project I would think. Dye would fade faster outside.
DIY Chair mat from plywood and carpet tiles jbwaechter Flooring 3 08-20-2009 06:29 AM
Gaps at baseboards after carpet install cometbus Flooring 9 10-01-2007 07:48 PM
Carpet Glued On OLD linoleum-HELP gradlass Flooring 5 09-30-2007 08:26 PM
Carpet Nightmare The Nomad Remodeling 3 09-30-2007 08:25 PM
glued down carpet...can I cheat? Dusty Flooring 3 10-10-2006 05:18 PM
