Painting On Cardboard Like Drywall? - Painting - DIY Chatroom Home Improvement Forum
Old 07-02-2012, 05:39 AM   #1
Painting on cardboard like drywall?
Hi there guys, new to DIY Chatroom. There was a leak a while back and it damaged one side of our wall pretty bad. I went on ahead and peeled off the paint. There is this cardboard like substance on the wall. I'm pretty sure it's dry wall, I think. I'll provide with a picture. I'd like to know how I'd go about fixing it and preparing it for paint. Thanks guys.
Picture:
http://www.freeimagehosting.net/6ipay
http://www.freeimagehosting.net/izty8
roxas2030 is offline   Reply With Quote
Old 07-02-2012, 08:44 AM   #2
Rewards Points: 6,652
Just get some Hot mud, let dry, sand & feather, finish, repaint. Easy one day job.
Old 07-02-2012, 08:51 AM   #3
Rubbin walls since'79
Brushjockey's Avatar
That might work.. or the moisture in the mud will cause the paper ( its a covering paper over the actual white gypsum that sheetrock is made from) to bubble .
What I do is coat it with something that will be a moisture barrier- Oil primer, a waterborne primer called Gardz or pigmented Shellac- called BIN. then taping compound (2x) , sand, prime and finish.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
Old 07-02-2012, 10:34 AM   #4
Renovations contractor
Bonzai's Avatar
What brushjockey says ... Plus use a utility knife to cut round the drywall paper to make sure there are no loose parts which happens if you just try to peel it back.
Home Renovations & Repairs
ADVENT HOME SOLUTIONS INC
Vancouver to Whistler & beyond
Bonzai is offline   Reply With Quote
Old 07-02-2012, 12:09 PM   #5
jschaben
Rewards Points: 502
I'm not 100% sure that's drywall, looks a little like masonite (hardboard). Kinda immaterial though as what Brushjockey posted would work fine in either case.
John Schaben
"Where all think alike, no one is thinking very much"
jschaben is offline   Reply With Quote
Old 07-02-2012, 01:27 PM   #6
Thank you guys so much! Is this a good sealer (1 gal. besides 1 qt.)?
"Kilz 1-Gal. Oil based White odorless Primer"- http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
Old 07-02-2012, 01:30 PM   #7
What is a taping compound?
Old 07-02-2012, 05:50 PM   #8
paper hanger and painter
chrisn's Avatar
Rewards Points: 224
It is not the best but if you already have it, it will work( maybe)
Old 07-02-2012, 08:17 PM   #9
Taping compound is like spackle only made for finishing drywall. Spreads easier, sands (usually) easier. Plus three is a very popular one. You can get it in small amounts ( maybe a qt- for sure a gal) . Use as big a mud blade as you can- I would be using a 12" and a 3" to get it out of the pail and onto the big blade.
Look for it in the sheetrock section- not the paint dept.
Old 07-02-2012, 08:52 PM   #10
liscenced electrician
Rewards Points: 538
looks like sound board to me. Which some people get confused an install instead of drywall. Its meant to be installed UNDER drywall
jimmy21 is offline   Reply With Quote
Old 07-03-2012, 03:15 AM   #11
Really appreciate the help guys. can you guys recommend a good oil primer ans taping compound, preferably from home depot or lowes?
Old 07-03-2012, 04:12 AM   #12
chrisn's Avatar
Rewards Points: 224
Brush has already posted about the compound and Cover Stain is also @ Lowes
Repairing old drywall inside corners before painting? Uncoiler Drywall & Plaster 7 07-08-2012 01:18 AM
Painting 'Bare' Drywall? ddawg16 Painting 11 06-02-2012 03:22 AM
painting new textured drywall ceiling Leanne1 Painting 6 02-14-2012 03:37 PM
Painting new drywall Leanne1 Painting 12 02-05-2012 05:05 AM
painting a room w/ both drywall and plaster walls J187 Painting 7 06-19-2006 06:33 PM
