-   -   Painting on cardboard like drywall? (http://www.diychatroom.com/f4/painting-cardboard-like-drywall-148875/)
roxas2030 07-02-2012 04:39 AM
Hi there guys, new to DIY Chatroom. There was a leak a while back and it damaged one side of our wall pretty bad. I went on ahead and peeled off the paint. There is this cardboard like substance on the wall. I'm pretty sure it's dry wall, I think. I'll provide with a picture. I'd like to know how I'd go about fixing it and preparing it for paint. Thanks guys.
Picture:
http://www.freeimagehosting.net/6ipay
http://www.freeimagehosting.net/izty8
gregzoll 07-02-2012 07:44 AM
Just get some Hot mud, let dry, sand & feather, finish, repaint. Easy one day job.
Brushjockey 07-02-2012 07:51 AM
That might work.. or the moisture in the mud will cause the paper ( its a covering paper over the actual white gypsum that sheetrock is made from) to bubble .
What I do is coat it with something that will be a moisture barrier- Oil primer, a waterborne primer called Gardz or pigmented Shellac- called BIN. then taping compound (2x) , sand, prime and finish.
Bonzai 07-02-2012 09:34 AM
What brushjockey says ... Plus use a utility knife to cut round the drywall paper to make sure there are no loose parts which happens if you just try to peel it back.
jschaben 07-02-2012 11:09 AM
I'm not 100% sure that's drywall, looks a little like masonite (hardboard). Kinda immaterial though as what Brushjockey posted would work fine in either case.:)
roxas2030 07-02-2012 12:27 PM
Thank you guys so much! Is this a good sealer (1 gal. besides 1 qt.)?
"Kilz 1-Gal. Oil based White odorless Primer"- http://www.homedepot.com/h_d1/N-5yc1...&storeId=10051
roxas2030 07-02-2012 12:30 PM
What is a taping compound?
chrisn 07-02-2012 04:50 PM
It is not the best but if you already have it, it will work( maybe):whistling2:
Brushjockey 07-02-2012 07:17 PM
Taping compound is like spackle only made for finishing drywall. Spreads easier, sands (usually) easier. Plus three is a very popular one. You can get it in small amounts ( maybe a qt- for sure a gal) . Use as big a mud blade as you can- I would be using a 12" and a 3" to get it out of the pail and onto the big blade.
Look for it in the sheetrock section- not the paint dept.
jimmy21 07-02-2012 07:52 PM
39 Attachment(s)
looks like sound board to me. Which some people get confused an install instead of drywall. Its meant to be installed UNDER drywall
roxas2030 07-03-2012 02:15 AM
Really appreciate the help guys. can you guys recommend a good oil primer ans taping compound, preferably from home depot or lowes?
chrisn 07-03-2012 03:12 AM
Brush has already posted about the compound and Cover Stain is also @ Lowes
