Painting With Calcimine - Painting - DIY Chatroom Home Improvement Forum
Old 03-14-2011, 11:05 AM   #1
Painting with calcimine
I have a large building with calcimine on walls and ceilings. Fortunately no one has put latex over it. Can I just recoat it with calcimine to avoid the difficulty of removal?
win@cpla-arch.c is offline   Reply With Quote
Old 03-14-2011, 11:35 AM   #2
Matthewt1970's Avatar
Rewards Points: 1,098
As long as nobody has painted over it then the Calcimine should just wash off the walls.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
Old 03-14-2011, 10:16 PM   #3
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Like Matthew said you need to wash the surfaces first, removing the calcium. You shouldn't just paint over calcium. Calcium can occurs when there is a moisture issue. If there is a moisture issue that will have to be resolved before painting
housepaintingny is offline   Reply With Quote
Old 03-14-2011, 10:55 PM   #4
Not Calcium, Calcimine. It's an old chalk type paint.
Old 03-14-2011, 11:02 PM   #5
I tried to give him a heads up by PM. I think he blasted through a couple of threads and went to bed. I've never dealt with calcimine, that I know of, is it a regional thing? I did some reading on it today. Interesting.
Old 03-14-2011, 11:57 PM   #6
(the original)
Rewards Points: 756
Ben Moore has an alkyd paint just for that purpose. Haven't had any experience with it, so I can't vouch for it except to say I've always had great results with all the BM products I've used.
And Zinsser Gardz is supposed to seal calcimine, but again I haven't used it for that particular purpose. I can tell you it's great for sealing after removing wallpaper, though.
And I've heard you can seal it with a penetrating oil based primer....but, once again....haven't done it...I'm being a big help, huh?
So, all that said, I'd remove it. But if you really don't want to, I'd suggest pick a product and try a small test area. Good luck!
js, you probably know it as "whitewash". Not regional that I know of, just old and often homegrown.
ratherbefishin' is offline   Reply With Quote
Old 03-15-2011, 04:19 AM   #7
paper hanger and painter
chrisn's Avatar
Rewards Points: 120
Originally Posted by ratherbefishin';609619[COLOR=red
]Ben Moore has an alkyd paint just for that purpose.[/COLOR] Haven't had any experience with it, so I can't vouch for it except to say I've always had great results with all the BM products I've used.
I have used both with sucess, but the BEST bet is to get it all washed off, oil prime and paint.
The Following User Says Thank You to chrisn For This Useful Post:
ratherbefishin' (03-15-2011)
Old 03-15-2011, 05:57 AM   #8
I worked with whitewash thirty years ago in older homes in Philly, but my only experience is doing unfinished basement walls. Applied it with a big mason's brush. I've never seen it, to my memory, on finished plaster walls. Can only imagine what that's like. Thanks.
I found this article yesterday doing some research, found it interesting http://www.plasterlord.com/notebook/fcalcimine.htm
Old 03-15-2011, 07:03 AM   #9
Rewards Points: 616
Reading the post fast I thought it said calcium. I have seen it on old plaster, especially after stripping off wall paper.
Old 03-15-2011, 07:37 PM   #10
chrisn's Avatar
Rewards Points: 120
Lots of it in the real old farm houses. You really need to remove it for best results, it is not all that hard but it takes some elbow grease
painting exterior door JP79ST Painting 18 05-18-2010 05:04 AM
painting my mom house supaflyz Painting 5 07-28-2009 03:34 PM
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 06:52 AM
Help! Painting problems on my finished garage mad dog Painting 7 07-23-2009 05:19 PM
Painting over latex and calcimine truebaca Painting 2 05-23-2009 05:54 AM
