Painting Cabinets - Painting - DIY Chatroom Home Improvement Forum
Old 04-13-2006, 04:28 PM   #1
Home Owner
Painting Cabinets
Hi there.
I recently purchased a condo and the kitchen needs an update. Right now I am repainting the kicthen cupboards that were originally green (uugh).
I have them sanded down right now and have a coat of primer on most of them. I am planning on going with a nice white and want a clean smooth finish.
What can I do to get the finest finish? Like I have noticed when rolling on the primer I see the rollers texture, is there a roller I can purchase that with make that texture a little lighter/smoother?
These are just wood doors, no designs or moldings. Just plain and flat. Someone told me to try a foam brush? Or even use a good brush, but wont I be able to tell that the paint was brush on?
I was also thinking about spray painting them? Sounds stupid but could it work for the image I want?
Hopefully someone can help. Thanks guys.
Leenders is offline   Reply With Quote
Old 04-14-2006, 09:47 AM   #2
Darylh's Avatar
A foam roller works well for this.The Cabinets in my picture were done that way but I would do a sample first If you can. A sponge roller leaves a very fine texture look and is easy to do.
Darylh is offline   Reply With Quote
Old 04-14-2006, 11:03 AM   #3
Home Owner
Cool thanks! I will give that a try. I didn't even think of those foam rollers that a good idea.
Old 04-16-2006, 11:48 PM   #4
Tired, Cold, and Damp
slickshift's Avatar
A quality paint with good leveling is what you are looking for
The foam rollers is probably a good idea also
slickshift is offline   Reply With Quote
Old 04-17-2006, 01:19 PM   #5
Contractor
You may also want to reduce the paint a little. It slows the dry time down but allows the paint to flow.
Teetorbilt is offline   Reply With Quote
My Kitchen Floor-Problems!!! Please Help!!! Fat b Flooring 3 01-25-2007 03:21 PM
Worth removing the cabinets before painting my kitchen? J187 Painting 7 10-08-2006 08:02 PM
Painting Kitchen Cabinets bgillette79 Painting 1 09-08-2006 05:31 AM
painting old cabinets pdagosta Painting 9 08-11-2006 09:16 PM
