Painting Cabinet Doors - Painting - DIY Chatroom Home Improvement Forum
Old 12-27-2012, 04:50 PM   #1
Painting cabinet doors
As I've mentioned in my other posts, I'm new to DIY projects so please excuse my stupidity!
I work in the kitchen of a family bar/restaurant where things can be a bit greasy. We have some cabinet doors in which the paint is quite gross looking, having collected grease from well over the past decade. I am looking to take the doors down, remove the paint, and re-sand the doors.
But from there I am not sure what to do. Do I seal it with something first before I paint? If so, what...and how long do I wait until painting can begin? And what products work best in a greasy environ? Or does that not matter so much so long as I clean them?
Attached is a picture of the door...gross indeed!
jmiza is offline   Reply With Quote
Old 12-27-2012, 04:59 PM   #2
Rubbin walls since'79
Brushjockey's Avatar
You said remove the paint, which would also remove the grease, so normal procedure from there. But that may be overkill if you plan to repaint.
What you need to do is remove the grease really well.
Krud Kutter is good, Soilex powder is good. Clean , and then clean again.
Sand to give a place for a quality primer to get a grip.
Use said primer, in this case an oil like Cover stain would be a good choice.
lightly sand that after dry and finish with 2x quality hard trim paint.
"It's better to come here with questions before you screw up than to come here after and ask how to fix them."- JS
Brushjockey is offline   Reply With Quote
The Following User Says Thank You to Brushjockey For This Useful Post:
ToolSeeker (12-28-2012)
Old 12-27-2012, 06:44 PM   #3
I have a call in to Chef Robert at Restaurant Impossible.
Old 12-28-2012, 04:36 PM   #4
paper hanger and painter
chrisn's Avatar
Rewards Points: 394
He would take a 10 lb sledge to it
vinyl kitchen cabinet doors th3225@q.com Carpentry 2 01-19-2012 03:12 PM
Spray Painting Kitchen Cabinet Doors suncowiam Painting 18 09-27-2011 05:13 PM
Painting New Interior Doors grommeck99 Painting 12 07-24-2010 02:52 PM
painting side by side front steel doors old salt Painting 3 06-04-2008 08:18 AM
Painting over polyurethane coated wood doors flashme18 Painting 9 04-19-2008 09:51 PM
