Painting C1915 Porch - Painting - DIY Chatroom Home Improvement Forum
Old 09-03-2013, 11:19 AM   #1
Rewards Points: 730
Painting c1915 Porch
I have an old house and am in process of sanding the wood porch boards, I'm guessing they are douglas fir, but not positive. In any case, I bought two gallons of porch and floor paint from Sherwin Williams. The salesman said it didn't need a primer, but I'm not sure I buy into this. I am in process of painting my house as well, so I have a gallon or two of oil primer laying around, it's also Sherwin Williams, should I apply a coat of that prior to the paint or not?
Thanks!
Master Brian is offline   Reply With Quote
Old 09-03-2013, 01:03 PM   #2
Rewards Points: 5,994
I would you already have it so it won't cost anything and it will give piece of mind. It will soak into the wood and help seal it.
The Following User Says Thank You to ToolSeeker For This Useful Post:
Gymschu (09-03-2013)
Old 09-03-2013, 01:55 PM   #3
painting c1915 porch
No, do not prime. You probably already have paint on the deck of the porch, just make sure that the paint you are applying is the same type, oil or latex. The process, after sanding and cleaning up the dust created from sanding, is to thin the first coat so that it will soak into the bare wood and stick to the scuffed areas on the existing paint. Follow this with a full stength coat for subsequent coats, 1 or 2 should be sufficent.
paintedfx is offline   Reply With Quote
Old 09-03-2013, 03:09 PM   #4
Rewards Points: 730
Actually, 75% of the old paint is peeling so badly that I'm sanding it pretty much down to bare wood. There are and will be little spots of what I presume is old lead based paint left over, but those spots are pretty soaked into the wood.
Old 09-03-2013, 03:42 PM   #5
Gymschu's Avatar
Rewards Points: 938
Listen to ToolSeeker. Wood that old and peeling that badly needs a slow drying oil primer to soak into the wood and give some bite to the topcoats. If you simply apply 2 coats of paint, you will end up with "dead" spots where those topcoats soaked into the old, dry wood.
The Following 2 Users Say Thank You to Gymschu For This Useful Post:
Jmayspaint (09-03-2013), ToolSeeker (09-03-2013)
Old 09-06-2013, 02:01 PM   #6
Rewards Points: 730
My logic also says pre prime and I did do 3' wide strip.... but the can doesn't give time between prime coat and being able to use the acrylic porch paint so I called the store and asked. He was very addiment that I shouldn't pre prime and said the paint would adhere better without the primer, that is the findings on tests. He recommend scuffing the dry primer to open back up the pores.
So with that I am asking again. ... what to do? Still prime? Prime then scuff? ....or just forget the extra step and possibly and off the primer I just put down?
I should also mention the primer I used was their quick dry. I just realized the replies said a slow dry! For some reason I have two gallons of this quick dry, but I do have a can of a slower drying primer as well! They are all oil.
Porch painting naf0 Painting 1 09-12-2010 03:33 PM
Leaking Roof Where House Meets Porch tazmajazz Roofing/Siding 7 08-25-2010 06:18 PM
Painting concrete porch with many paint layers underneath normjennifer91 Painting 1 07-13-2009 07:18 AM
Painting square porch columns katie74 Painting 2 05-13-2009 12:37 PM
Painting exterior porch floors mlupa Painting 2 03-17-2009 04:02 PM
