Painting A Brownstone In NYC - Painting - DIY Chatroom Home Improvement Forum
Old 04-08-2011, 10:33 AM   #1
Painting a Brownstone in NYC
Hello All,
I own a brownstone in NYC, built in 1886. It has MANY coats of paint on it. My plan is the remove the paint with Peel away 1, which I tested and it got straight down to the brick. I would love to have it repointed but it is out of my budget range. So after removing paint, I plan to power wash, then what? I have read so many different forms of advise. So should I use brick fill, followed by latex primer then top coat? What brands would you recommend?
Thanks in advance
David51st is offline   Reply With Quote
Old 04-08-2011, 03:10 PM   #2
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
Originally Posted by David51st View Post
Hello All,
Thanks in advance
You can use any quality 100% acrylic latex, after priming first. Use a masonry primer, such as Sherwin Williams Loxon
housepaintingny is offline   Reply With Quote
Old 04-10-2011, 07:48 PM   #3
Rewards Points: 252
I'm located in the heart of Brownstone land in Brooklyn =) The best thing i would suggest is XIM peel bond primer followed by two coats of Ben Moore Exterior Aura. There are some other good primers our there as well, fresh start, Ben Moore's 066 acrylic masonry primer, etc.. but the peel bond, IMO, is worth the extra 30 bucks a gallon.
Many contractors will also suggest Thorolastic on brownstones. Different look than paint, but it has excellent adhesion and durability and you can get it in whatever color you like. Might pay to look around the nieghborhood and see what other people have done - both products will give their own unique look. Shame you can't have it repointed - nothing like the original brownstone look...
good luck!
mazzonetv is offline   Reply With Quote
Old 04-13-2011, 04:42 PM   #4
Thanks all.
One more question. I have read several post where people say to sand the brick, after power washing. Is this a good idea? and if so would it be a wet sand like a 5 Inch Concrete and Stone Wet Polishing Kit with Diamond Pads or dry, which seems like a ton of dust.
Old 04-13-2011, 06:54 PM   #5
Matthewt1970's Avatar
Rewards Points: 1,098
Yes, a good masonry primer is designed to expand somewhat when drying to fill some of the voids in the brick/masonry and give superior adhesion. I am not sure if sanding will help or not and you really should check for lead before you do anything. If you follow that advice, some guy 100 years from now will be complaining about all the layers of paint on the house but NOT complaining about it peeling.
Latex Primer: Good for Drywall, that's about it.
Behr Paint: The plastic buckets are good, that's about it.
New Member: Painting Contractor Induspray Introductions 3 01-04-2010 07:50 PM
painting my mom house supaflyz Painting 5 07-28-2009 02:34 PM
Help! Painting problems on my finished garage mad dog Painting 7 07-23-2009 04:19 PM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 03:07 PM
Painting over a sponge painted wall Snowdog Painting 3 03-16-2008 11:13 PM
