-   -   painting brickwork (http://www.diychatroom.com/f4/painting-brickwork-31514/)
Pandi 11-09-2008 05:54 PM
painting brickwork
I`m intending to paint an internal brick wall. Do I need to apply anything before I start painting? and do I use exterior brickwork paint? I assume I need to use a brush and not a roller?
All advice gratefully received.
Nestor_Kelebay 11-10-2008 02:43 AM
No, "exterior brickwork paint" will be a latex masonary paint that's meant to be used on the exteriors of brick (or other masonary) buildings. Masonary paints are latex paints that allow H2O molecules to pass through the paint relatively easily, but are impervious to liquid water.
Most people wonder how something can allow H2O molecules to pass through it, but not water, and the answer becomes obvious once you recognize that the distance between H2O molecules in water is larger than the diameter of a single H2O molecule. And, surface tension keeps the H2O molecules in liquid water sticking together rather than dispersing like they would as humidity in air.
If you imagine a latex resin as being a wire scrunched up into a ball, then you can imagine that air could easily pass through that scrunched up wire because of the spaces between the various sections of wire. The acrylic resins used in masonary paint are chosen because the spaces between the wire sections are larger than the diameter of a single H2O molecule, but smaller than the average distance between H2O molecules in liquid water.
Consequently, individual H2O molecules can pass through masonary paint relatively easily, but not liquid water.
This is important when you're painting the outside of a brick building because any paint you use on the outside won't prevent moisture from migrating into the wall, it'll only prevent it from leaving the wall by evaporating from the exterior surface of the brick. So, if you use an impermeable paint like an high gloss oil based paint, then moisture will be trapped and can accumulate in the wall until you get pockets of water formed in the voids in the brick. That's cuz humid air can get into the wall at electrical outlets and gaps under baseboards and form frost inside the wall all winter long. Come the first warm days of spring, that frost melts and forms water inside the wall that may get absorbed into the brick or may form pockets of water within the brickwork. But, come the night following that first warm day, and you get subzero temperatures again, and that melt water freezes and expands. That can cause cracking of your bricks (called "spalling") due to water inside the brickwork expanding as it freezes.
So, masonary paints are designed to minimize the risk of freeze/thaw damage to masonary walls by allowing any water inside the wall to evaporate as readily as possible through the paint. That keeps the wall as dry as possible, and a dry brick is a happy brick, even if it's hot or cold out.
In your case, the brick face you'll be wanting to paint is on the inside, so painting it with any kind of paint will help prevent moisture from getting into the wall.
So, you don't need to use a masonary paint. ANY paint will work well. And, brick is rough enough that you don't need to worry about priming. Any paint will stick well to the rough surface of brick without priming. I'd clean the surface of the brick of dust and any loose mortar sand first, tho.
You might want to use a block filler over your brick if it's really rough brick, too, just to get a smoother looking surface.
Also, think twice about painting brick. It's easy to put the paint on, but it's not easy to remove that paint should you decide that it was a mistake to paint it. ANY paint you put over that brick is going to be softer than the brick and will therefore be more prone to getting marked and scuffed up, and that means you'll then be having to clean marks off the painted brick just like you clean marks off of painted drywall or plaster (and paint over really stubborn scuffs that won't clean off). You've got a near maintenance free wall surface now, why make work for yourself by painting it so that it requires more cleaning (and painting) instead of keeping the hard mark-resistant wall you have now?
slickshift 11-10-2008 07:42 AM
A quality acrylic (latex) primer rated for masonry should be applied first
Probably a combination of brush and roller would be best, but use whatever works for you and your particular project
Top coat with a quality acrylic wall paint
Do not use exterior paints for interior
...and consider once brick has been painted, realistically it won't be going back to raw brick
At least in a DIY project anyway
The only truly successful removal process involves specialized and pricey equipment, and a fair amount of skill, and is best left to pros
Blondesense 11-11-2008 01:44 PM
Great technical advice.
Add me to the list of people who would not paint brick. And I have brick in every single room in my house!!!
If you must, two things you might want to research.
I'm a newbie (never done this) but I have heard it is possible to stain brick a different color.
If you go with paint you might consider using several colors. One for the mortar, and two or three mottled on the brick itself. Sort of a faux finish kinda thing. I've just seen pictures online, but IMHO it looks much nicer and more natural than a solid color.
Sudmom 11-12-2008 01:12 PM
painting brickwork
We are also painting brick. We just bought an old school that we are renovating for our business. The walls in they hallway have years and years of paint on them. We are trying to scrape off the cracked, chipped old paint. It is very time consuming and not doing the greatest job--Any suggestions short of sandblasting would be helpful. Also, any ideas for painting that would hide as much of the chipped away areas as possible.
Thanks!
Nestor_Kelebay 11-12-2008 07:46 PM
There are many companies that will sandblast indoors. You just have to put up plastic around the work area to keep the sand and dust confined to the work area. It's done all the time.
Another option you might want to consider is to install 1X3 or 1X4 wooden strapping to the brickwork, and then fasten drywall to the wooden strapping.
