Painting The Bricks Around The Burner - Painting - DIY Chatroom Home Improvement Forum
Old 01-27-2008, 04:21 PM   #1
painting the bricks around the burner
i want to paint behind my woodburner..its surrounded by bare bricks..what paint should i use..?
debz is offline   Reply With Quote
Old 01-27-2008, 05:19 PM   #2
Rewards Points: 506
If the wood-burner is in use, and these bricks get hot, you will need some sort of high-heat paint. I would suggest stopping by your local Sherwin Williams store. Since they are a company with a complete line of coatings, including industrial ones, they are likely to have one that can help you, or they can order one for you.
If the bricks do not get hot, you should use a primer intended for masonry, and then any high-quality wall paint. If the bricks have any kind of soot on them, you will need to prime with a shellac-based primer, such as Zinsser BIN. (Use a respirator if you go that route... it is nasty stuff.)
SirWired
sirwired is offline   Reply With Quote
Old 01-27-2008, 08:27 PM   #3
Pro Painter
Hi-temp paint will work. Clean soot before attemting to prime, as it will just smear otherwise.
joewho is offline   Reply With Quote
Old 01-28-2008, 06:22 AM   #4
makes of hi temp paint
thanks for the advice..i need makes of paint or suppliers in the uk that produce these hi temp paints..
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 01:24 AM
painting a woodstove JAVAMAN Painting 7 05-12-2009 06:47 AM
Garage drywall painting haylo75 Painting 18 11-12-2007 08:13 PM
couple questions about painting on different surfaces joeyboy Painting 3 08-19-2007 02:33 PM
Painting exterior bricks helpless handyman Painting 8 07-19-2007 09:40 PM
