Painting Brick On Top Of Existing Paint / Water Proofing Basement - Painting - DIY Chatroom Home Improvement Forum
Old 12-12-2010, 01:39 PM   #1
2md
painting brick on top of existing paint / water proofing basement
Ok, I have to questions here .. i have an older row house with brick basement walls .. the walls have been painted at one point and the paint is not falling/chipping . also, at the 2 ends of the basement, there is a bit of water and moisture coming through .. I will be renting out this house and required to take care of the water problem as well as the chipping paint ..
I talked to 2 different contractor .. One suggested sandblasting the paint away all the walls and spray the 2 wet walls with some kind of water proofing sealant. leave the other 2 walls without painting.
My other contractor wants to spray the 2 wet walls with sealant as well but simply prime and paint the other 2 walls without removing the old paint!
the price for both job is almost the same. (can i mention price here?!!!)
i know sandblasting does some damage to the walls, but i really don't care ..
i am not so sure about painting on top of old chipped paint although he swears it will stick and will give me a 4 year warranty in writing! would it work?
What is my best option here? If I was to do the job myself, what would be the best way (product) to seal the wet walls? and best way to remove the old paint? DO the past paint strippers work?
Thanks.
2md is offline   Reply With Quote
Old 12-12-2010, 02:15 PM   #2
Gymschu's Avatar
Rewards Points: 670
My first thought is you really need to find out what's causing the moisture problem.........gutters clogged, ground sloping towards house, etc. Any work I have done in the past when it comes to waterproofing is to get that old paint off so you can properly seal the concrete block. UGL works pretty good as long as it's not MAJOR water infiltration.
Gymschu is online now   Reply With Quote
Old 12-12-2010, 03:23 PM   #3
2md
i just started researching different products and very confused .. from what understand so far water based, polyurethane, or acrylic bases sealers may not be as good as silicon based products . but i am unable to find any silicon based brands for some reason not on the Internet and not in home depot .. any ideas?
Old 12-12-2010, 03:49 PM   #4
Painting Company, NY
housepaintingny's Avatar
Rewards Points: 616
First you do need to resolve the problem as to why you have water coming in the basement. Then I would remove any loose/flaking paint, clean the walls and spray on Sherwin Williams Shercrete which is a flexible, breathable, acrylic waterproofer that you can get in virtually any color that you want.
housepaintingny is offline   Reply With Quote
Old 12-12-2010, 04:27 PM   #5
2md
i am afraid there is not much i can do to resolve the problem unless i am willing to spend thousands of dollars .!!! It is a row house built in 1980, so no coating of any kind on the other side of the wall .. if it wasn;t for the concrete back yard and from concrete side walk, the basement would have been more like a pool!
I have done some more research in the last couple hours and i keep seeing sheecrete as a good product .. my next question, best way to remove old paint?
Has anyone used the paste stuff? I saw 2 products in Sherwin Williams called Peel away 1 and Smart Strip .. are they suitable for using on the whole basement?
Old 12-12-2010, 06:23 PM   #6
Rewards Points: 616
I've never used peel away on a masonry surface, but on wood substrates it works great. If you decide to use the SW Shercrete you don't have to strip the paint, as you can paint over it with the Shercrete as long as it is not peeling or flaking. Shercrete is our go to product for most interior-exterior masonry surfaces as it is a waterproofer and it also adds aesthetics
Old 12-12-2010, 06:49 PM   #7
2md
Thanks houspaintingNY .. sounds like shercrete is the product to go .. i do have the paint chipping peeling away .. so i think i have to remove the old stuff b4 sealing the wall with sherecrete ...
still searching chemical strippers on brick .. not a lot of info out there which kinda surprsies me .. they all say they work on brick, but all the demos show wood .. and i wonde who long it will take to do the job? i think i have aboit 700 sq/feet of walls to clean and 150 sq/ft to water proof/seal ..
Old 12-14-2010, 08:33 AM   #8
ccarlisle's Avatar
Hmmm. Explain that to me: "brick basement walls"...and "rowhouse"
By a rowhouse, I think about several conjoining houses that share a common wall above ground and common basement walls. If you put a hole in your wall, wouldn't you see into the neighbor's basement?
Brick walls...not much support there unless it is just a brick veneer put there to look nice but without structural value. What do you have? CBUs underneath? ie concrete blocks?
“The average American woman is about 25 pounds heavier than she was in 1960...Recognizing obesity as a disease will help change the way the medical community tackles this complex issue that affects approximately 1 in 3 Americans,”
ccarlisle is offline   Reply With Quote
Old 12-14-2010, 10:11 AM   #9
Rewards Points: 558
you can use this product to water proof your basement yourself. http://www.sanitred.com/BasementWaterproofing.htm
epson is offline   Reply With Quote
Zinsser Bathroom Paint canuckjack Painting 7 08-27-2012 08:00 AM
Paint the brick or not? Walkway? Advice NEEDED! Carssson General DIY Discussions 24 09-08-2009 05:52 PM
Paint riddle... Please help me fix this? techprincesse Painting 8 08-24-2009 10:00 AM
Bad Bad Paint job to fix. Cleaning brick overspray and other problems. (Pics) ewheatley Painting 1 05-19-2009 01:08 PM
painting brickwork Pandi Painting 5 11-12-2008 06:46 PM
