Old 11-02-2008, 11:19 AM   #1
Painting behind wood stove
We are renting a place that has a wood burning stove. The protective barrior behind the stove between the stove and the wall is white we want to paint it black, does anyone know what type of paint we should use?
donnieh1 is offline   Reply With Quote
Old 11-02-2008, 12:54 PM   #2
Matthewt1970's Avatar
www.stovepaint.com
I am not sure how much of an effect turning it from white to black will have on it's ability to reflect the heat.
Old 11-02-2008, 04:10 PM   #3
that stuff works great, but I would keep it white.
Allison1888 is offline   Reply With Quote
Old 11-04-2008, 10:28 PM   #4
BBQ Black in quart cans. This paint (flat finish) is made for BBQ repaints. Available at your local hardware store.
casselli is offline   Reply With Quote
Old 11-08-2008, 09:42 AM   #5
I have used that stuff before, perfect blend, smells a little the first time you fire it up, then no odor. Neutral colors work best.
MarkC
MarkC is offline   Reply With Quote
OSB Stronger than Plywood? Weathermaker01 Flooring 15 12-22-2012 10:06 AM
Ready to paint the porch! Oil or latex? Leah Frances Painting 8 07-26-2011 08:29 PM
Do I need to replace a rotten sill plate met Carpentry 8 07-11-2008 10:14 AM
Repairing the wood for painting bofusmosby Painting 4 06-17-2007 12:55 AM
