Painting Beadboard - Painting - DIY Chatroom Home Improvement Forum
Old 07-25-2011, 01:52 AM   #1
ptb
painting beadboard
hello,
I am about to install 400 sq. ft. of beadboard. Material is fir and is 1x6x 20' lengths. Installation is on large outdoor covering. Does wood need to be primed or painted on "back side"? Outdoor covering has a roof so beadboard should be watertight. thx
ptb is offline   Reply With Quote
Old 07-25-2011, 04:56 AM   #2
PTB, it's always good policy to back prime any exterior wood that you can.
Old 07-25-2011, 05:19 AM   #3
paper hanger and painter
chrisn's Avatar
Rewards Points: 150
and don't forget all the edges
The Following User Says Thank You to chrisn For This Useful Post:
jschaben (07-27-2011)
Old 07-25-2011, 07:01 AM   #4
old guy contractor
tcleve4911's Avatar
Rewards Points: 530
and especially the end cuts.......
tcleve4911 is offline   Reply With Quote
The Following User Says Thank You to tcleve4911 For This Useful Post:
Old 07-25-2011, 07:46 AM   #5
Rubbin walls since'79
Brushjockey's Avatar
Great that you thought of that. As a pro I'm called in to finish after everything is installed and I know it would last many years longer if backpriming has been done.
Brushjockey is offline   Reply With Quote
Old 07-25-2011, 09:39 PM   #6
I stand humbled, and corrected, before my esteemed peers. Yes, by all means, prime all six sides of wood.
Old 07-25-2011, 09:46 PM   #7
Learning by Doing
Leah Frances's Avatar
Sheesh. Even I know that :P
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 07-26-2011, 12:51 AM   #8
ptb
thank you, oil based primer or does it matter.
Old 07-26-2011, 12:54 AM   #9
ptb
is it still considered "exterior wood" even though it will have a wont have any direct contact with elements? Similar to covered porch. thanks all.
Old 07-26-2011, 04:49 AM   #10
chrisn's Avatar
Rewards Points: 150
yes, SLOW dry
Old 07-26-2011, 11:32 PM   #11
ptb
can you topcoat with latex paint if you use oil based primer?
Old 07-27-2011, 05:12 AM   #12
chrisn's Avatar
Rewards Points: 150
YES 2 coats
Old 07-27-2011, 07:01 PM   #13
Leah, I knew that, I was just sleeping on my watch.
PTB, If the wood is outside, it requires exterior products/treatment, even if it isn't directly exposed to certain elements, it's still exposed to cold and damp.
Old 07-27-2011, 08:43 PM   #14
ptb
thank you kindly. on a side note, any opinions on color of outdoor fans if outdoor ceiling will be white. I know this is subjective and individual preference, but i m sure many of you have seen many outdoor fan/ceiling color combinations and can comment on what looks clean and sharp. maybe pics from jobs you worked or saw. Thanks
Old 07-27-2011, 08:49 PM   #15
Learning by Doing
IMO - White.
Beadboard Backsplash nthomp16 Building & Construction 12 02-06-2011 04:28 PM
?about painting beadboard sychopants Painting 7 12-09-2010 01:19 PM
Newby painting over existing fascia, beadboard appledeco Painting 3 07-26-2009 06:52 AM
Granite backsplash over beadboard? Asil65 Building & Construction 10 03-23-2009 12:02 PM
Interior door painting and too much/too little paint richbl Painting 2 08-26-2008 04:07 PM
